ETP LS7 4" bore flow numbers
Old Jan 14, 2006 | 02:14 AM
Cary@Perf-Induction's Avatar
Collections Hold
Default ETP LS7 4" bore flow numbers
I just flowed our LS7 4" bore cylinder head, jut wanted to share the numbers with ya'll. We downsized the intake valve to a 2.125 and exh. to a 1.600. We also relocated the valve centerlines to maximize the radial distance around the valves. They will still use the stock LS7 rocker arms and intake manifold.
The valves are a touch longer so we could raise the spring pads to allow for any size/diamenter valve spring, even 1.650 dia. I think they would be sweet on a LS2 or 402 combo. I still yet have to cc the chamber and ports. The intake port volume was reduced from the original LS7. They exhaust port was also made to match up with existing ls1 headers/manifolds.
Intake = 2.125
.100 73
.200 154
.300 236
.400 287
.500 321
.550 336
.600 345
.650 350
.700 335
exh. 1.600
.100 56
.200 110
.300 166
.400 200
.500 215
.550 220
.600 222
.650 226
.700 230 271 with 1 7/8 pipe
thanks,
cary
Old Jan 14, 2006 | 02:43 AM
MuscleMachine's Avatar
Very nice numbers,I'll have to look into those.
Old Jan 14, 2006 | 07:35 AM
proautoman's Avatar
These will fit my 415 project 4.060 X 4.00 Cast Iron Block and I will be able to use the
TPIS headers that are bolted to AFR 205 heads Iam currently using on a 346 CID.
Iam going to be ordering MAhle Pistons - Let us know when you CC the Head
Chambers- These will utilize the LS7 Intake and Rocker Arms Correct
Awesome flow numbers
Pricing Thanks
Old Jan 14, 2006 | 10:37 AM
Mizfit MotorSports's Avatar
What valves are you using. Steel or Titanium
Old Jan 14, 2006 | 10:40 AM
Collections Hold
Default valves, cc
I haven't cc'd yet, but the chambers will be around 70 on a 4" bore.
they will come standard with stainless valves. price will be around the 3000 mark complete.
Old Jan 14, 2006 | 10:48 AM
MeentSS02's Avatar
Kleeborp the Moderator™
Could you post up stock LS7 head flow numbers in this thread for quick reference by any chance?
Also, I was looking on your site, and although the intake side of these flows better, the exhaust side of your 225cc 11* heads flows better at nearly all ranges. Any particular reason for this?
Old Jan 14, 2006 | 03:32 PM
Collections Hold
Default yes
yes,
it is a flow bench thing. we merely post flow numbers for exhaust ports because people want them. I can tell you that flow numbers for exhaust ports mean absolutely nothing. they are for reference only. but the reason they dont flow as good is because the valve is closer to the bore than on the 225's etc. The stock LS7 is the same way. this one actually flows a bit better than the stock ls7, as far as flow bench figures go.
Old Jan 14, 2006 | 04:00 PM
beardWS6's Avatar
How much longer before you catch up on your back orders.
Old Jan 14, 2006 | 05:18 PM
MeentSS02's Avatar
Originally Posted by cary et performance
yes,
Oh yeah...the intake numbers are definitely where its at. I was just wondering the reason behind it...thanks for the reply! Now to find a good intake manifold that'll go in an F-body.
Old Jan 14, 2006 | 05:24 PM
Miles in Florida's Avatar
I assume that doesn't include the LS7 rocker arms, right? Looks like GM parts direct and SDPC have the rocker arms for under $10 a piece (intake and exhaust), so that only adds $150. The LS7 intake manifold is about $300, and so is the LS2/LS7 throttle body. Any other special things required to put these heads on an LS1?
Old Jan 14, 2006 | 05:41 PM
Quickin's Avatar
This isn't the 265 type head is it? I'm confused. Doesn't the 265/41 flow like 382cfm at .700 lift.
Is the 265/41 head better flowing than the LS7 type you're talking about for my 4.100 bore 436 stroker?
Old Jan 14, 2006 | 06:01 PM
Beast96Z's Avatar
This is not the 265cc LS1 type port. This is the LS7 style head they have set up for a 4" bore. Some people were wanting to use LS7 heads on the 408/402 ci motors, but the smallest bore they could go on was a 4.060". ET stepped up and made a small bore version for those guys wanting the LS7 heads and manifold for stock bore through 4.060".
Old Jan 14, 2006 | 06:18 PM
NumberOneSled's Avatar
Will these be the best heads you guys offer for a 4" bore?
Old Jan 14, 2006 | 06:36 PM
Beast96Z's Avatar
It depends on what your trying to do. These heads peak by .600", wearas some of there other castings flow past that. If your running big lift, you might benifit more from a 255cc head. It'll be interesting to see the port volume when he gets it up. Then we can compare it to the others.
Old Jan 14, 2006 | 06:58 PM
Drewman's Avatar
Sweet. I've been looking forward to these.
Old Jan 14, 2006 | 07:04 PM
Quickin's Avatar
Dumb me I just realized it.
Old Jan 15, 2006 | 11:30 AM
dame's Avatar
Email sent sir.
Old Jan 15, 2006 | 09:34 PM
Tom@SpeedInc's Avatar
I notice your 4" bore LS7 heads flow roughly somewhere between the LS1 240 or 255 heads.
If someone was to be building a iron block 408 should they go with LS1 style heads or is their advatanges to LS7 heads?
Old Jan 16, 2006 | 05:52 AM
Collections Hold
Default whats better
right now it is a toss up. Until we test these three combos back to back, we really wont know iether. My thoughts are that the LS7 manifold will help support more power up top where a FAST intake may start to fall. just my guess for now though.
Old Feb 8, 2006 | 10:29 AM
Drewman's Avatar
So are these backordered like everything else? Does the same "8 week" delivery estimate apply?
