New LS2 C5R Type Mini Heads
this is saudisam incase you still don't know who this is
so the heads won't work on a stock ls1 block , but will they,, say ,, work on an iron block bored 30 over?? or does the bore have to be 4.065 ??
how about the valvetrain? still stock or ls7 style?
https://ls1tech.com/forums/generation-iv-internal-engine/435051-l-92-heads.html
Nate
https://ls1tech.com/forums/showthread.php?t=435051
Nate
SAMMY!!! Good to hear from you too!
You should be able to use the L92 heads on a 30 over iron block no problem. The L92 rockers are unique and required. They are similar to the LS7... but are a 1.7 ratio instead of 1.8 (LS7). Wait until the CNC houses get ahold of these heads... they are going to be killer. And yes, they will bolt right up to your motor. And if I remember correctly you have 1 7/8" headers already dumping into a 4" exhaust, right? We just need to wait a little bit until GM releases the low profile intake for these heads... shouldn't be too long. I heard you were in the 9's now... have you been able to keep the heads down?
Bill
cf. http://www.ls1.com.au/forum/showthread.php?t=49289
