Limit of LS2 stock bottom end?
If forged internals WILL be needed, would anyone be able to give me a ballpark price on how much it would be to get them installed? Seems like it would be a very extensive process and cost some coin just for the install alone, not including the price of the actual components.
Thanks for the insight.....
whats everyone else think??????
Chris.
Also, it is really hard to tell how much damage is being done to the internal parts, especially when the damage may occur gradually over time....
Thanks for the response tho. I believe I have also heard of a number of people running around with those kinds of numbers on completely stock blocks without a problem.....just want to be positive about this before jumping into it and spending all that $$$
Thanks!
At APS we have a stock engined twin turbo LS1 at APS with appox 540 whp (has better than stock valve springs) that has over 60,000 miles on the clock and it's still going at strong as ever, uses about 1 pint of oil about every 2500 miles, all good and hope this helps.
Peter
Peter
Now here's another Q:
If 2 identical cars with identical motors making identical power, which car would be faster? Really, which would have a more linear power curve, AKA more area under the power curve.
I would think that a N/A application would be a bit peakier in making the high HP numbers while a FI application would be a bit more linear, thus making it the faster of the identical cars (with identical drivers if you want to really get technical). Am I wrong in this assumption? Is the N/A actually better?
Just so it's clear, the cars would have:
Naturally-Aspirated:
Heads
Cam
Full Exhaust
Intake manifold
CAI
Forced Induction:
Roots Style SC
Full Exhaust
CAI
Saying that both these cars made exactly the same (lets say 450rwHP for argument's sake) peak HP numbers, which would have the more linear curve?
Thanks for all the helpful info folks
The stock LS2 pistons are the weak point in the whole system. If you even go into a tiny bit of knock under power, say goodbye to the top ringlands.
These pistons aren't the high quality Mahle casting found inthe LS6, I am pretty sure they just took the LQ9 setup and put it in the LS2. So, however much they are making in the LQ9's is how much you can go on the LS2.
One last question. What could one realistically expect from this set-up:
Cartek Stage 3x Heads
Cartek Stage 2X Cam
FAST 90/90 Intake
Volant CAI
SW Full Exhaust
All out of an LS2 M6. Would this be streetable for daily driver use?
Thanks again for everything.
