Rods Bolts
Old Apr 10, 2006 | 08:28 AM
TA BOY's Avatar
Default Rods Bolts
DO THE LS2 HAVE THE SAME PROBLEM THAT THE LS1 HAVE WITH THERE CONNECTING RODS BOLT.
Old Apr 12, 2006 | 12:25 AM
glennhl's Avatar
Rod bolts have been fine in LS1's since 2001, so I would assume LS2 rod bolts are fine.
Old Apr 12, 2006 | 09:09 AM
TA BOY's Avatar
Well Thanks For The Info
Old Apr 12, 2006 | 11:01 AM
Mike454SS's Avatar
They're like the first thing to fail at high RPM in a stock bottom LS1
Old Apr 12, 2006 | 11:15 AM
TA BOY's Avatar
Yea Thats Why I Was Asking. To See If I Should Change Them Out Or Not.
Old Apr 12, 2006 | 05:08 PM
Steve1969LS1's Avatar
I just bought some ARP rod bolts for my LS2.. figured that since I am swapping oil pans I might as well go with the better bolts..
ARP now makes front cover, water pump, intake manifold and oil pan bolts!
Old Apr 12, 2006 | 09:45 PM
DocEwww's Avatar
Good question...I would assum yes, theyre still the first part to fail.
Old Apr 12, 2006 | 10:19 PM
Katech_Jason's Avatar
LS1TECH Sponsor
People with LS2s are still buying ours for added insurance. I don't know the tensile strength of the stock bolt, but ours are 160,000 psi.
Old Apr 14, 2006 | 12:29 AM
glennhl's Avatar
Do a search and most people say the 2001 and newer rod bolts are good for any stock bottom end up to 7000 rpm. Depends on what you want to do with the engine or do you just want to spend money?
Old Apr 14, 2006 | 05:44 PM
DocEwww's Avatar
I think hes trying to avoid that by upgrading the bolts.
Old Apr 14, 2006 | 10:14 PM
427 LS1's Avatar
You might want to double check your tensile strength rating, I believe they are higher then that - 240-260,000 psi
Old Apr 15, 2006 | 09:18 PM
glennhl's Avatar
All depends what he wants to do. Is he building a race engine that is going to rev past 7000 quite often, then it's a good deal. If he is going to keep it stock and not rev past 6500 then it's a big waste of money!
Old Apr 16, 2006 | 10:27 PM
HottLS1Z's Avatar
Thats not completly true...GM Started using the rod bolt that is in the LS6 and LS2
in the LS1 in the 2000 model year. Thats why I didnt do the MS3 cam on my 98Z but did
on my 00 with it shifting at 6800. The bolt can hold 6800 all day while the 97-99 design is
only rated too 6400.
Old Apr 16, 2006 | 10:38 PM
'Trust''s Avatar
But still, you cant beat the assurance of ARP's for <$100
Old Apr 17, 2006 | 09:22 AM
firefighter's Avatar
I never skimp on fastners.... hell my last rebuild of an old school SBC I spent almost $500 in fastners alone, studs EVERYWHERE.
