LS3 & L92 Info
Old Nov 25, 2006 | 03:43 PM
  #261
04Yukonxl's Avatar
Originally Posted by StreetnStrip
u are correct but I thought he was asking what the lowest bore u could go with with using stock LS7 heads. In the GM performance book it says 4.065. I have heard that there was someone do machine work on these heads so that u could use them on a smaller bore motor but I forget who it was.
There may be a smaller valve/bore head in the future.
Old Nov 25, 2006 | 03:47 PM
  #262
52172's Avatar
there is it is the l92 head and it will fit on a 4.0 bore.
Old Nov 26, 2006 | 09:50 AM
  #263
04Yukonxl's Avatar
I was referring to the LS7, not the L92.
Old Nov 26, 2006 | 10:38 AM
  #264
52172's Avatar
etp has a small bore ls7 head it fits on a 4.0 bore and has the12 deg valve angle unlike the l92 heads.
Old Nov 27, 2006 | 04:49 PM
  #265
Sparetire's Avatar
I'll have to find pics of that. I mean, valve size and bowl size is just set. How can you adjust a head to fit a smaller bore? Is there a way to alter the seats so you can use a smaller valve?
Old Nov 27, 2006 | 05:08 PM
  #266
StreetnStrip's Avatar
Closed ex-Sponsor Account
I love ur signature
Old Nov 28, 2006 | 07:45 AM
  #267
MrDude_1's Avatar
ETP actually has a diffrent LS7 casting. thats why they can machine them to fit the smaller bore.
really though, it IS an alum head.. you could weld it up, heat-treat and machine it.. if you wanted.
Old Nov 29, 2006 | 03:50 PM
  #268
Sparetire's Avatar
I love ur signature
It's just such a good universal statement.
Old Nov 29, 2006 | 03:52 PM
  #269
Sparetire's Avatar
Good point and good info. It just blows me away how the aftermarket is right there with production platforms now. The availability of CNC, cryo, and other tools these days is amazing. This stuff was for big race teams and engineering firms only just a decade ago.
Old Nov 29, 2006 | 04:30 PM
  #270
Wnts2Go10O's Avatar
so...what soring compressor is everyone using with these heads on the motor? (crane compressor no longer works )
Old Nov 29, 2006 | 06:47 PM
  #271
04Yukonxl's Avatar
There's always the old bar method.
Old Nov 29, 2006 | 09:46 PM
  #272
Wnts2Go10O's Avatar
nope, not enough clearance to use it. (have one) i almost fubar'd the threads. ill probably get the ratchet spring compressor thats on thunders site
Old Dec 5, 2006 | 09:57 PM
  #273
91_RS_LS1's Avatar
Does anyone have the parts # on the complete Holden intake manifold with injectors and 90mm TB? Also, what rods/pistons are needed? I'm trying to get a parts list to see how much I'll need for a build. Thanks in advance.
Old Dec 6, 2006 | 11:22 AM
  #274
280Z28's Avatar
Is the Holden intake you refer to the same as the L76?
Old Dec 6, 2006 | 03:12 PM
  #275
91_RS_LS1's Avatar
I don't know. I'm wanting to find the one that is designed for cars. They are supposed to make more power at higher RPMs than the truck/SUV intakes.
Old Dec 6, 2006 | 04:28 PM
  #276
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Yeah, I saw your thread on that. Pretty crazy, but like you said at least you didn't get hit with the retainer.
http://www.sdpc2000.com/catalog/1980...e-By-Wire-.htm
The rods depend on what you plan on using. If you're going iron block 408, you'll need 6.125 rods for a 4 inch stroke. Pistons would most likely have to be custom if you want to get the most out of the combo. You could use some off the shelf 4.030 bore ones, but they'd have to be flat tops or domes. Even then you might have problems with achieving the proper SCR you desire. Milling the heads is an option, but then you're reducing P2V clearance.
To put it in context this is going to cost a hell of a lot more than just putting a LS1 in your car like your original plan was.
Old Dec 6, 2006 | 05:36 PM
  #277
91_RS_LS1's Avatar
Thanks for the link. I was thinking they were less, but that is still a good deal. Any idea as to how to convert it to cable throttle?
Yea, I know this is going to be a heck of alot more. I'll probably just put in an LS1/T56 from a wrecked donor car and then build the L92 in the summer of '08. And even then, it will probably just be a stock one with a larger cam. They should have some pistons for the engine out by then. I wouldn't want to be loosing power due to lower compression. What rods would I need for a stock stroke?
Old Dec 6, 2006 | 09:40 PM
  #278
GIGAPUNK's Avatar
Default $$$Crazy Deal$$$
My injectors alone cost more than $528.
Not to mention throttle body, fuel rails, and intake.
Old Dec 6, 2006 | 10:47 PM
  #279
91_RS_LS1's Avatar
I wasn't complaining about the cost. Far from it. What kind of injectors cost over $528?
Old Dec 7, 2006 | 08:38 PM
  #280
91_RS_LS1's Avatar
Oh. That's... a lot of flow. Those going on a F/I engine?
What length rod should I use to get a stock stroke (or just buy the stock GMs)? Could I use the 6.125 rods and run them in a stock block? Would the stock crank work with these rods? (sorry for all the questions, but my knowledge is pretty basic)
