LS3 & L92 Info
Old Aug 2, 2006 | 03:35 PM
  #141
Robin L's Avatar
LS1Tech Sponsor
Default Pictures of the L92 Intake
Here are a couple of shots of the Intake for the L92 Heads
Robin
Attached Thumbnails LS3 & L92 Info-l92-intake-1.jpg   LS3 & L92 Info-l92-intake-2.jpg
Old Aug 2, 2006 | 07:34 PM
  #142
Richard@WCCH's Avatar
Very nice and clean! Those intakes should make a nice setup for the cars with the 90mm ttb.
Richard
Old Aug 2, 2006 | 09:28 PM
  #143
TURBHOE's Avatar
12 Second Truck Club
Robin
so what one is that the holden or the truck? or is it neither one?
Old Aug 2, 2006 | 09:46 PM
  #144
Wnts2Go10O's Avatar
that be the perrty car intake i believe. gmpp is also making a carb intake if oim not mistaken
Old Aug 3, 2006 | 08:19 PM
  #145
ls1perfcar?'s Avatar
https://ls1tech.com/forums/lsx-parts-sale/553085-l92-heads-springs-valves.html
if anyone is interest in some l92 heads.
Old Aug 7, 2006 | 10:23 PM
  #146
IMD's Avatar
IMD
where can one purchase the caddy intake?
Old Aug 11, 2006 | 02:48 PM
  #147
BAKED's Avatar
Does the truck intake outflow the car intake? Other than clearance issues what is the benifit of the car intake? Also what are the prices of both?
Old Aug 11, 2006 | 02:55 PM
  #148
Wnts2Go10O's Avatar
the truck intake was traditionally designed for low end grunt while the car intake was for more hp in the midrange-top end
Old Aug 11, 2006 | 03:07 PM
  #149
BAKED's Avatar
Ahhhhh, ok. So are the car intakes avalible or not? if so how much?
Old Aug 11, 2006 | 03:11 PM
  #150
Wnts2Go10O's Avatar
not yet, they were saying a couple weeks til release and gm was saying 500 for the entire intake, tb, rails, injectors assembly. sdpc is gonna put a top end package together. heres hoping for an 1100$ L92 top end package
Old Aug 11, 2006 | 03:51 PM
  #151
BAKED's Avatar
OK, I guess I'll just keep watching this thread.
Old Aug 13, 2006 | 10:58 PM
  #152
Kory 88Iroc Lt1's Avatar
subscribing
Old Aug 13, 2006 | 11:34 PM
  #153
Wnts2Go10O's Avatar
Old Aug 15, 2006 | 05:02 PM
  #154
Cop Car's Avatar
is the L92 in the Caddy going to be an E85 motor? i really hope so, that way you can bump up the compression to use all 110 octane of it. then all id have to do is get an E85 compatable fuel tank and fuel lines and it would be complete pimp...
Old Aug 15, 2006 | 05:33 PM
  #155
rjgto's Avatar
Are the sleeves in the L92 about .075" thick like the other LS blocks?
And how many LS1/LS2 components are a bolt-on?
Old Aug 15, 2006 | 08:14 PM
  #156
Has the L92 headed engine sold in a production escalade yet? Or is it available starting in 2007?
Thanks,
Kory
Old Aug 15, 2006 | 09:18 PM
  #157
9ball's Avatar
Here was a question raised over at ls1gto:
So what everybody doing to bring up the exhaust flow, GMHTP mag has them at 198cfm at .800 lift!!! Classic truck head exhaust side flow, for torque, not high rpm HP. I imagine that these heads will need porting done asap to balance out flow between intake and exhaust for Street car app's. No??
Any answers??
Old Aug 16, 2006 | 08:50 AM
  #158
Jed Z06's Avatar
Can someone tell me what gaskets the L92 use?
I have a 4.062 bore, on my 415, and think the l92 gaskets would work for me.
Any head gasket part #?
Old Aug 16, 2006 | 01:07 PM
  #159
Wnts2Go10O's Avatar
Any answers??
exactly how many are goiing to run THAT much lift on these heads?
Old Aug 16, 2006 | 01:17 PM
  #160
WicketMike's Avatar
Would the L92 heads straight out the box with the intake setup compliment a stock LS2 GTO or would there be a better cam that would go with it. (what specs)
