Another Cheatr Cam dyno
Old May 21, 2006 | 06:50 AM
xstang's Avatar
Default Another Cheatr Cam dyno
I posted my dad's track results and dyno numbers earlier, but here is the same setup with AFR heads/Kooks headers....
C6 Z51
Mods: Honker Intake, Cheatr Cam, AFR 205s, Kooks.....
Old May 21, 2006 | 08:28 AM
DavidNJ's Avatar
Ok, what is the 40hp difference here between Patricks car and this.
First questions, what is compression ratio and what is the intake manifold; is it a FAST 90mm?
Old May 21, 2006 | 08:37 AM
rollinna65's Avatar
Wasn't Patrick running stock manifolds and a y-pipe setup? If so, this vette has long tubes and true duals on its side which would account for a lot with a bigger cam and well flowing heads.
Old May 21, 2006 | 08:50 AM
xstang's Avatar
This is an LS2... I made 392/365 before the Kooks headers... The Headers gave me 29RWHP/21RWTQ.... This is with the stock LS2 intake... I plan to have Tony port a fast for me in the near future...
Old May 21, 2006 | 09:00 AM
DavidNJ's Avatar
A 364 with headers, 231/236 lsk/xer cam, AFR205s I would expect to be 460-500rwhp based on other posts. The LS2 has a 90mm tb, doesn't it? Does the FAST add that much on the LS2? Isn't Patricks car making 460 or so on a 347?
Old May 21, 2006 | 09:29 AM
xstang's Avatar
Yeah the intake is what really holds this car back... I will probably be really close to 450Rwhp with Tony's ported Fast. The Ls2 intake is junk
BTW this cam is only 215/232
Old May 21, 2006 | 09:59 AM
Mr Z51's Avatar
Is it still driving like stock(any surging issues). How does it sound with the headers. Can you hear the cam in it or not???
Old May 21, 2006 | 10:15 AM
xstang's Avatar
The cam doesn't lope/surge at all.... I would say it drives just like stock. Since I added the headers, you can hear the valvetrain a little more, but nothing significan't. Matter of fact, if you are running the AC you can't hear the springs/ valvetrain at all....AT WOT, the tone changed for the better.... Sounds like a sportscar should...
fyi- No drone cruising...
Old May 21, 2006 | 10:29 AM
Redline-Motorsports's Avatar
We have done a couple 05' Z51 6 speeds with Cartek heads and cam, Kooks headers, stock intake and made consistent 453-455 RWHP and torque in the 422-425 range.
Probably could have made more with an larger cam but we wanted the car to be fairly street friendly!
Old May 22, 2006 | 06:47 AM
xstang's Avatar
Yeah that sounds about right.... I don't have an UD pulley either, so that is another 8-10 laying on the table....
