A helpful LS7 fitting we are making
Old Jun 5, 2006 | 04:24 PM
Reckless's Avatar
Super Moderator
Default A helpful LS7 fitting we are making
We had been getting a few calls for an oil pan adapter to convert the LS7 pan to AN style fittings. We machined a few and had them hard anodized. We sell the adapters with the o-rings for the pan side for $99. This will allow you to use whatever oil tank you want and use standard AN style fittings of your choice.
Attached Thumbnails A helpful LS7 fitting we are making-ls7-adapter.jpg   A helpful LS7 fitting we are making-ls7-adapter-1.jpg
Old Jun 5, 2006 | 04:38 PM
Anonymous's Avatar
10 second playa
Nice!
Old Jun 5, 2006 | 06:14 PM
Bill Reid's Avatar
Make one for the Z06 oil tank too please
Bill
Old Jun 5, 2006 | 06:39 PM
Phoenix 5.7's Avatar
now yall need to slap a twin super setup using those rotrex superchargers yall have on an LS7
Old Jun 5, 2006 | 09:20 PM
JustinOlson's Avatar
What volume tank do you recommend for the ls7? What size lines are sufficient? -8 an?
Regards,
Justin
Old Jun 6, 2006 | 08:19 AM
Reckless's Avatar
Super Moderator
The fittings we make will use a -12AN fitting. Not really practical to make a fitting for the oil tank side. I think most folks will use an aftermarket tank with AN fittings. If you have the GM tank, just hack off the GM fittings and weld on aluminum AN fittings. Any competent welding shop can handle this.
All you need is the appropriate weld on fitting such as this -12AN fitting from Earl's (997112ERL)
Old Jun 6, 2006 | 11:06 AM
Classic's Avatar
Probably a dumb question, but how well does the dry sump pan fit in the fbody chasis? Do the location of the outlets work with headers/etc?
Old Jun 6, 2006 | 01:45 PM
Reckless's Avatar
Super Moderator
I really don't know. We have not performed any swaps here.
Old Jun 6, 2006 | 01:49 PM
Katech_Jason's Avatar
LS1TECH Sponsor
It fits fine with the BMR k-member. No header clearance issues with the TPIS headers.
