air pump into vacuum pump
Old Jun 25, 2006 | 10:24 PM
KRAZY K 2000 TA's Avatar
Default air pump into vacuum pump
so i was thinking while sitting in the rain at the track i am going to hook up my air pump so that the inlet takes air from my valve cover.and jjust vents to atmosphere.and see if it makes a difference at the track.any input on this idea?
Old Jun 25, 2006 | 11:22 PM
618HAWK's Avatar
Intrested as well, this thought has crossed my mind. Had pump disconnected at the out put. And I was suprized how much air it puts out. Need to see what kind of pull it actualy has. Might be worth while with a catch can as well.
Old Jun 25, 2006 | 11:28 PM
ya think i should go go through another pvc in my drivers side valvecover or how should i hook to the valve cover? this might work
Old Jun 26, 2006 | 06:16 PM
MIGHTYMOUSE's Avatar
whatever you do, make sure you have an oil separator. i didnt when i tried this a few year ago and it killed the air pump in a couple months.
it was also annoying hearing it cuton and off all the time (had it on a tps switch)
Old Jun 26, 2006 | 06:22 PM
duke of cruel's Avatar
To make a proper vacuum, you need some pump power, and i am not sure
if the smog actually makes enough. But an vac pump DO release a lot of power, especially at high rpm, gave 14 hp on my ford tt. The position of the sucker in the valve cover is importent to. Moroso makes a nice one.
DoC
Old Jun 26, 2006 | 09:41 PM
going to use a seperator from home depot for air compressors,take my fuse panel apart under the hood where the relay is and hook the relay trigger wire to a switch and use it at the track only.try to get it done tommorow,going back to the track this weekend.
Old Jun 27, 2006 | 04:00 AM
aboadnan's Avatar
There is a real vacuum that came in the 81-85 Olds engine and it is under
the AC compressor and it is belt driven.
It a v8 that came on Buik and Olds B and C bodies 81-85 and in some
Caprices station wagons up to 1990.
Old Jun 27, 2006 | 12:15 PM
strokedls1's Avatar
We have done it any so have many others. It is a waste of time as it does not pull enough vacuum for high rpm. We ended up converting to a moroso custom built setup that works well, but is a race car only design.
Old Jun 27, 2006 | 08:51 PM
aboadnan's Avatar
Are you talking about the air pump or the vacuum pump?
Old Jun 27, 2006 | 11:15 PM
C_Williams's Avatar
Default This works!
This works!
Old Jun 28, 2006 | 01:44 AM
strokedls1's Avatar
I was talking about using the air pump as a vacuum pump. It does not pull enough air at wot. You need a belt driven unit to make it work.
Old Jun 28, 2006 | 03:58 AM
ls1408cp's Avatar
yes the air pump doesnt pull enough. my friend put one on his nova with a blower and could only get like two pounds of vac. at idle. so its really good for nothing
Old Jun 28, 2006 | 07:10 AM
lol the mechanical pumps are nowhere near as free as the stock air pump to try.
also in reguards to the actual question he is asking if it will move air through the engine, which it will.
he is not asking it to pull a hard vaccuum, which it won't.
Old Jun 29, 2006 | 10:14 PM
exactly free is free i understand the real vacumm pump is the schiznitz but its my streetcar and thats a little much but that pic of the pump is cool what kind of setup is that.
Old Jun 29, 2006 | 10:25 PM
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by C_Williams
This works!
Wow, that tensioner looks a lot like ours.
Old Jun 30, 2006 | 03:59 PM
NemeSS's Avatar
Old Jul 10, 2006 | 08:17 PM
Dutchman's Avatar
This works!
Nice setup.
Is this set up available as a kit to purchase either reply here or PM me as to where I can get my hands on this Vacuum pump setup...Thanks
Old Jul 11, 2006 | 11:40 AM
snketr's Avatar
I think that's A&A's vacuum setup. A&A Corvette.
Old Jul 12, 2006 | 01:33 AM
Dutchman's Avatar
I'll ask again is their anyone out there that knows were I can pickup this Vacuum pump kit for an LS1 Ive had no luck to date tracking this kit down.
Many thanks
Peter.
Old Jul 12, 2006 | 06:12 AM
speedracer5532's Avatar
Many thanks
Peter.
You need to talk to Charlie Williams at A&A Corvette, 805-278-4107. It is definitely a nice setup.
