Patriot Performance LS6/LQ9 Style heads $1,095.00 Assembled !!
From now until Labor Day, Patriot Performance will have all our our CNC ported LS6 style and LQ9 heads on sale. The price on these will be $1,095.00 per pair, assembled. These heads will come with Ferrea 6000 series valves, our Orginal Patriot Gold Springs, Titanium retainers, Super 7 Locks, Machined Spring Bases, and Viton Rubber seals. These prices include both stage II and III heads. Prices do not include shipping or head bolts.
Bare CNC ported version of these heads will also be available for only $795.00 per pair !!
Don't forget these heads can be made for bore sizes 3.905"-4.125" and chamber sizes from 59cc-72cc.
Good Lord I wish you would have had that deal back in march I would have saved $300 on the Stage II set I bought.
Folks I'ld suggest get'n on this if you have been thinking about get'n a set of heads this is a very nice deal.
----Edit (cause I don't want to double post)-----
Gunnar any idea when you'll have a stage II port ready for the L92's (curiosity is get'n to me).
I figure Patriot will probably be one of the first one's out with a complete set that are tweaked (just hope they'll still fit a LS2's stock bore when there ready).
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Nate
LQ9 spec's page with flow #'s
http://sites.reachtheworld.tv/waterN...05235&DID=1225
LS6 Spec's page with Flow #'s
http://sites.reachtheworld.tv/waterN...05234&DID=1225
if i go with a set of assembled heads not sure which ones and a cam 224 228 .581 .588 114 not sure on cam either right now. (still looking) but thinking about those specs what else am i gonna need to install it, which i know gaskets and bolts but anything major?
We are working with the L92 heads, however it will be a little longer. We are concentrating on our Predator heads right now.
Our 2.02"/1.57"/64cc head would be a good choice. We can supply the OEM GM MLS gaskets for $35.00 each and an OEM bolt kit for $25.00.
Gannar said: "We do have customers who use a stage III heads on a stock bore motor. We have done several sets for guys like Bob at Exotic who uses them on forced induction set ups. For these we do a custom stock bore chamber that is designed for the best flow with this valve set up."
Gunnar can you do me a set of Forced induction heads stageIII like this for the small bore for $1,095.00 per pair? Will these clear stock pistons with LS6 cam on stock rockers as well?
Yes, we can do you a set like this. You will need to check your PTV clearance. Give Bob at Exotic a call about the PTV clearance, he may have specfic information for that set up. He can fix you up with a set of these heads at the $1095.000 sale price.
Interested in heads for my magnacharged 6.0. Would stage III be what I want?
