New GMPP LSX Block
Old Aug 18, 2006 | 09:32 AM
  #101
MrDude_1's Avatar
Originally Posted by black_knight
I like cheese.
i love lamp!!
(seriously though, cool pics)
Old Aug 18, 2006 | 11:48 AM
  #102
LSxChevelle's Avatar
Can't wait to see it at SEMA!!
Old Aug 18, 2006 | 11:58 AM
  #103
JMBLOWNWS6's Avatar
******* sick! Man I want a aftermarket block allready! LOL
Old Aug 18, 2006 | 01:39 PM
  #104
Abdullah's Avatar
Originally Posted by GMPP
Here's some photo teasers. This is pre machining.
OK, i changed my mind i want to do LS7 427ci engine. for how much this LSX block would be? is it the same style as LS1 block style?
Old Aug 18, 2006 | 03:02 PM
  #105
NemeSS's Avatar
Default "distributor hole"
will these blocks be equipped with the "distributor hole" aka as the bore where the cam sensors locates in the 97-2004 gen 3 motors which are not equipped with dod??
or at least a provision for one,
thanks
Old Aug 18, 2006 | 03:09 PM
  #106
MrDude_1's Avatar
thanks
you mean the GenIII style rear mount cam sensor?
Old Aug 18, 2006 | 03:33 PM
  #107
GMPP's Avatar
Street pricing should be between 2000 and 2500. We are trying our best to keep the price down.
Nearly all Gen III and Gen IV parts will fit. However, it requires Gen IV style cam sensing.
Old Aug 18, 2006 | 03:35 PM
  #108
NemeSS's Avatar
YES!
aka as the "distributor hole"
Old Aug 18, 2006 | 03:36 PM
  #109
NemeSS's Avatar
DOH!!
Old Aug 18, 2006 | 07:03 PM
  #110
OAG's Avatar
OAG
Old Aug 18, 2006 | 07:17 PM
  #111
black_knight's Avatar
Originally Posted by OAG
So what are some recommended options/costs for something that can take up to the 2000 HP?
I'm going to go out on a limb here and say that 2000 HP is what the block can take, not what it is expected to make. At least outside of the sponsored races...
Could be wrong. Just speculating.
/Just waiting to see what the price/specs will be on the Aluminum version...
Old Aug 18, 2006 | 07:22 PM
  #112
Phoenix 5.7's Avatar
well, W2W got a worked over iron block up to 1500hp, and that was with like 370ci, so i can see a block designed for very high HP could take 2000 with the right work and setup
Old Aug 19, 2006 | 10:36 PM
  #113
Tuf-Titan's Avatar
This block is going to open up a whole new can of worms
Old Aug 21, 2006 | 07:57 AM
  #114
GMPP's Avatar
Between the extra bore wall thickness, and the 6-bolts per cylinder, this new block will handle significantly more boost than the W2W project engine.
Old Aug 21, 2006 | 07:59 AM
  #115
GMPP's Avatar
DOH!!
This should not be a big issue, there are sources to reconfigure the wiring and sensing.
Old Aug 21, 2006 | 08:40 AM
  #116
427's Avatar
427
I can't wait!!! This should fix all the current problems with high hp engines. Patiently waiting(kinda)......
Kurt
Old Aug 21, 2006 | 09:34 AM
  #117
Noyzee's Avatar
8 second mod
this block needs to hurry up. im going small block this winter, but this block could sway me back!!
Old Aug 21, 2006 | 11:25 AM
  #118
Camaro_Zach's Avatar
honestly this does need to come out sooner, im ready to get a sleeved aluminum block...but this way id save 1g and be safer....
Old Aug 21, 2006 | 12:53 PM
  #119
Stang's Bane's Avatar
Just a question, how do you have more bore wall thickness with the same bore spacing? NOT being a smart ***.
Old Aug 21, 2006 | 01:11 PM
  #120
Sleeves are thicker??
