New GMPP LSX Block
Old Aug 21, 2006 | 01:13 PM
  #121
NemeSS's Avatar
Originally Posted by GMPP
Between the extra bore wall thickness, and the 6-bolts per cylinder, this new block will handle significantly more boost than the W2W project engine.
so when will a GMPP 4 in. stroke crank be available *hint* hint*
hell, even its made from nodular iron, like the stock ones
dont even have to be forged.
Old Aug 21, 2006 | 01:16 PM
  #122
LSxChevelle's Avatar
That would be nice to see!
Old Aug 21, 2006 | 01:41 PM
  #123
Abdullah's Avatar
Sorry, I changed my opinion again I don't want to build up engine that consists of : ported GM LS7 heads, custom mid range camshaft, ported GM LS7 intake manifold, GMPP LSX block, 4.000" stroke eagle crank,6.125" Scat I-beam rods, 4.125" Diamond forged -2cc valve releifs pistons, Clevite H Main Bearings, Clevite H Rod Bearings and good brand's piston rings.
Old Aug 21, 2006 | 01:54 PM
  #124
firefighter's Avatar
Here's some photo teasers. This is pre machining.
Uhmm is it just me (it might very well be) but does that block look aluminum?
Old Aug 21, 2006 | 03:42 PM
  #125
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Subscribing.
Old Aug 21, 2006 | 03:47 PM
  #126
Stang's Bane's Avatar
Looks that way to me also.
Old Aug 21, 2006 | 04:00 PM
  #127
SStrokerAce's Avatar
Guys, remember that the LS motor is going NASCAR racing in Busch North so GM has to make some GMPP stuff like blocks and heads. GM has been pushing this motor platform forward in racing circles (Daytona Prototype, Speed World Challenge, Busch North, ALMS) and if the design of the heads on the LS7 is any indication, not to mention the C5R stuff looking like Sb2.2 stuff internally then it may turn into the new Chevy Nextel Cup motor a while down the road. Who knows there, they never approved the ROX block for Cup racing, which was a bonehead manuver but whatever.
A $2,000 GMPP Bowtie style block is a killer deal.
Bret
Old Aug 21, 2006 | 05:00 PM
  #128
Yes $2K for a bowtie style block is fantastic but most of us want ALUMINUM so I'm just hoping the price is still reasonable. Aluminum for about $3K and able to do a 4.2" bore........... If that is possible.
Old Aug 21, 2006 | 07:42 PM
  #129
LSX Wizard's Avatar
Firefighter, you'll never be able (yeah, I know.... never say never) to put a 4.2" bore in an aluminum block with a 4.40" bore center and still have any sleeve material left. Max bore that I've seen is right around 4.17 in an aluminum block.... that's really pushing it.
I'm guessing it's Iron becuase the stock blocks do a fair job handling decent power, and also because aluminum blocks are quite exxpensive to make in aftermarket form.
Old Aug 21, 2006 | 08:07 PM
  #130
LSX Wizard's Avatar
Originally Posted by Stang's Bane
Just a question, how do you have more bore wall thickness with the same bore spacing? NOT being a smart ***.
In stock form, the iron 4.8, 5.3, and 6.0L blocks (and older 305 and 350 blocks) have water between the bores, this is know as non-siamese. As you add material around the bores the water gets thinner, and if you make the bore walls thick enough, then they join together and this is know as siamese. (Please don't flame, I'm assuming there's some out there that don't know this already). Adding more wall thickness beyond this point only adds material to the thrust surfaces, which is where you really need the support anyway. If the thrust surfaces are too thin, they flex and ring seal becomes an issue and can also lead to erratic ring, piston and bore wear.
I'm guessing that the od of the bore walls on the thrust side give a minimum of .150" (wall thickness between the bores at 4.250" bore) if you can really bore it to 4.250. 4.250 + .300 (2 times the wall thickness) would be 4.55" od. That's huge! I believe W2W used an iron 6.0L block for thier 1500hp buildup and I don't think the od. of those bores goes much beyond 4.25"
I can't wait to see one of these.... can't wait to punish my first one either!
Old Aug 21, 2006 | 08:50 PM
  #131
BTW if anyone has seen the 6.0L block they are some beefy ****'s W2W's only trouble with that motor was lifting the heads and pressurizing the cooling system not any problems with block distortion. I'll have to put one of those 6.0L iron beasts on the scale at work, but for a non-siamease block that SOB is strong.
Bret
Old Aug 22, 2006 | 08:40 AM
  #132
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
So the summary is:
-Iron block from GM, kinda of like a Bowtie LSx block
-Standard 4.125 bore? Just needs a hone?
-Different water jackets?
-Can use LS1 or LS2 or ??? crankshaft?
-Uses what cam and crank sensors?
-Stronger iron than the 6.0 blocks?
Old Aug 22, 2006 | 08:49 AM
  #133
LSX Wizard, I have seen some one here (on this site) claim they cam do a 4.190" with their sleeves in a LS2 block. I was thinking that all of that was pretty close on the 4.4" bore spacing. But I am kinda hoping it will be possible with the new blocks. Otherwise just buy the LS7 it's allready 3K and you can do a cleanup hone on the 4.125" what 10-20 thousandths? So I'm hoping they have got some "kryptonite" cylinders and maybe you can get a little more bore out of them. We'll see what happens. It will prolly take too long for me and I'll just use a sleeved block for my swap.
Old Aug 22, 2006 | 10:03 AM
  #134
383ss's Avatar
a sponsor on here will do a 4.1875 dry sleeve and 4.200 wet sleeve ls1 block.
Old Aug 22, 2006 | 10:36 PM
  #135
LSX Wizard's Avatar
Ok guys no insult intended here, but let's do some math. 4.40 bore center, minus 4.200 bore = .200" for both cylinder walls. This leaves .100" per liner wall **if** they either a) touch, or b) interlock (BTW, interlocking sleeves is expensive, and seldomly done correct). Anything less than this would make for a poor liner. Most aftermarket sleeves are either 1/8" or 3/16" thick for use in procution iron blocks..... why would you ever consider anything less for an aluminum version? The stock liner in the LS7 is .0875" thick, and this is ridiculed as too thin.
Now this assumes you want to have any kind of wall thickness to your bores, which now causes some issues (maybe only for me, but I'm sure also for others that know how to make reliable, serious power). If you have .100" walls, now you have no original material (also known as "parent material") between bores. In an iron block that is relatively strong (as compared to an aluminum one) you can get away with less material between bore and still maintain strength, however, if you remove this material from an iron, let alone an aluminum version, and create a wet sleave condition, you have lost a tremndous percentage of strength. Anyone in thier right mind would avoid this situation.
I'm quite sure this is why the World aluminum block is only advertised to go 4.125, they know the limitations of how far to intelligently go with bores and sleeves. They allow for a couple rebores before you have to replace sleeves.
Old Aug 23, 2006 | 06:22 AM
  #136
IMHO the only reason we need large bore LS blocks like this made in CAST IRON is because that's what the boys down in NC need to run in those roundy round cars. The similarity between the LS7/L92 style heads and SB2.2 heads in general design and the fact that you could make these things a canted valve design with a little help says GM is fishing the LS motor to take over for the oldschool SBC with the current NASCAR parts on it.
Bret
Old Aug 23, 2006 | 06:35 AM
  #137
matt346ls1's Avatar
Bret
My thought exactly, and I love it, this will bring the LSx world to a new level.
Old Aug 23, 2006 | 07:08 AM
  #138
Quick Carl's Avatar
Here is the FEA analisis of the 4.202" bore in the 500CI motor S.A.M. is working with. They already made over 900 HP with a 250 nitrous shot on the pump gas mild street build. I see the sheet metal intake is finished, so the stock intake and throttle body are going away.
http://www.erlperformance.com/techbr...eve_Design.pdf
The sleeves are "siamese" at the upper cylinder where all the cylinder pressure is. Max distortion of .001" (@ well over 1000 HP,1200 Ft/LB torque, 600 shot of nitrous) occurs around 90 degrees ATDC, well down in the cylinder. The sleeves are Ductile iron (over 110K psi Tensile) and states the cast iron (40K tensile) would be an issue at the same cylinder pressures and wall thickness.
Old Aug 23, 2006 | 08:13 AM
  #139
ScottyRocket's Avatar
The boy in NC have already submitted a new engine to the guys running the show. They are saying they need to keep up with Toyota and their cup engine is way ahead of everyone else already.
They also have a "Spec" LS based engine coming out for one of their touring circle track series.
Old Aug 23, 2006 | 09:49 AM
  #140
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Well, the possibilities here are endless. This opens the door not only for development at the highest level (read that as Cup teams), but the net effect is that racing improves the breed. That means we (as the end users) get access to better and better products. Look at the current surplus parts (like rods and sb2.2 stuff) you can buy from cup teams. Imagine being able to buy ls specific hard parts from your favorite (or heck even un-favorite teams).
"Uncle Robin", welcome to the site. Your exploits in the Ford world are well known, and your prescence along with your info and insight is greatly appreciated.
