LS1 oil pan on LS2, any issues?
Old Aug 10, 2006 | 10:21 AM
99vette pilot's Avatar
Default LS1 oil pan on LS2, any issues?
I bought a used LS2 to replace my LS1 and trying so save $$$ anywhere possible. Has anyone used an LS1 oil pan on an LS2? I know the part numbers are the same for both, just wondering about the redesign. Are there any issues or problems this would create? Thanks for your help.
Old Aug 10, 2006 | 10:36 AM
DrkPhx's Avatar
The LS1 pan will fit the LS2 no problem. Just make sure you have the correct version of the LS1 pan for clearances between the chassis and pan.
Old Aug 10, 2006 | 11:03 AM
C5 KIDD's Avatar
using my LS1 pan on my LS2 with no issues. had to use spacers though foro the crank, but if your LS2 is stock your ok.
Old Aug 10, 2006 | 01:40 PM
Noyzee's Avatar
8 second mod
ls1 pan on my ls2 as well. no issue
Old Aug 11, 2006 | 09:57 PM
blkvett01's Avatar
Ls1 pan on Ls2 it fit great!
Old Aug 14, 2006 | 05:15 PM
TJ's Avatar
TJ
why would you need a spacer[and where] for the crank?
Old Aug 14, 2006 | 06:05 PM
ozws6's Avatar
For the 4" stroke crank used to produce 402 ci, the windage tray needs to be spaced down to clear the longer throw of the crank.
Old Aug 14, 2006 | 06:42 PM
TJ's Avatar
TJ
thunk ya pho increasin' my smartness. :hillbilly voice:
