LS7 heads..
Old Aug 14, 2006 | 01:57 AM
Cop Car's Avatar
Default LS7 heads..
ok, i was told that i can use LS7 heads on the 6.0 LQ4 becuase it has a 4.000 inch bore. is that correct?
i looked around the sponsors and didnt really see where anybody had a head/intake package. i remeber one sponsor had them together for about 1500.. any help?
Old Aug 14, 2006 | 08:35 AM
slt200mph's Avatar
The bore is to small for the LS7 heads
Old Aug 14, 2006 | 09:09 AM
ScottyRocket's Avatar
A quick look through any of the ls7 head threads could have gotten you this info.
Old Aug 14, 2006 | 10:31 AM
TKAYRC3's Avatar
ET Performance has a 4" bore LS-7 Head for 6.0 blocks.
Old Aug 14, 2006 | 10:58 AM
slt200mph's Avatar
The question was about LS7 heads..ET is an aftermarket head not a GM LS7 head..the GM LS7 head is not compatable with the 4.0 bore..
Old Aug 14, 2006 | 11:21 AM
Haans249's Avatar
You're also looking at 2500-3K depending on which head you get, i.e. GM or ET Perf. Not 1500.
Old Aug 14, 2006 | 03:24 PM
Cop Car's Avatar
thought the L92 heads were the same heads as the LS7, just not cnc ported. the L92 has a 4.06 bore. LQ4 has a 4.00 inch bore. are you telling me that the .06 makes the diffrence that the heads cant be used on it?
Old Aug 14, 2006 | 03:42 PM
Haans249's Avatar
LS7 heads and L92 heads are not the same thing. There is tons of info in regards to what you're asking already posted.
Use the search option,
Adrian
Old Aug 14, 2006 | 04:34 PM
Cop Car's Avatar
Adrian
thanks, i already did like 4 times, reguarding LS7 and L92 heads. thanks for being so friendly and helpful
Old Aug 14, 2006 | 05:13 PM
TJ's Avatar
TJ
L92 LS7
15 deg 12 deg
2.16 intake valve 2.2 intake valve
4.06 bore 4.125? bore
intake rockers are different as well due to intake valve spacing
L92 head also has a larger chamber, so just a tad less compression.
there is a TON of stuff in a search, but i agree with you, some exact answers to your questions are hard to find.
Old Aug 14, 2006 | 05:36 PM
HEMIETR's Avatar
The L92 heads should provide a great bang for the buck option. $375ea assembled. The intake rockers are less than $8ea as well. A good set of springs and push rods you're playing ball.
Old Aug 14, 2006 | 08:10 PM
Haans249's Avatar
Simply typing "LS7 Heads" into the search option, hope these can help you out!
https://ls1tech.com/forums/showthrea...ight=ls7+heads
Best,
Adrian
Old Aug 14, 2006 | 09:39 PM
Cop Car's Avatar
the current issue i have with L92 heads is that you cant use LS1/2/4/6/7 intakes... have to use an L92 intake, and im sure that it dosent breath well up top. wish i could fit an LS7 intake on it.
Old Aug 14, 2006 | 09:44 PM
Haans249's Avatar
GMPP has just released a carb style intake for the LS7 heads and the L92 heads, so you shouldn't have any problems with breath upstairs
Old Aug 14, 2006 | 09:48 PM
Cop Car's Avatar
i want to stay FI
Old Aug 14, 2006 | 09:51 PM
LSxChevelle's Avatar
GMPP has a composite intake for L92's now...
Old Aug 14, 2006 | 09:59 PM
Here is the thread...
https://ls1tech.com/forums/generation-iv-internal-engine/552392-pictures-l92-intake-gmpp.html
Old Aug 14, 2006 | 10:19 PM
TJ's Avatar
TJ
im gonna need a bigger carb
Old Aug 14, 2006 | 11:00 PM
dug's Avatar
dug
How much can the iron block be bored out? .060" over?
Old Aug 15, 2006 | 08:06 AM
Haans249's Avatar
Originally Posted by Cop Car
i want to stay FI
I don't get what you're saying here...if you want to stay FI, then whats the problem? This is the perfect intake for forced induction...
If you're talking about Fuel Injected, which would be "EFI", then these intakes will still be your best bet for upper rpm flow, because they have fuel injector bungs that need a simple drilling to accomodate your favorite fuel injector.
Adrian
