All motor ls2 times????
im going all motor next year ls2 408
not looking to brake any records, just looking to have fun, but what are people seeing.
this will be in a car set up for drag racing. im thinking low 10's high 9's without an issue. i know i will have some suspention tweeking to do, but pretty sure i can go low 10's no problem.
car went 11.0 with a compleat n2o tuneup in it, 19* of timming, suspention set up for spray, tight *** converter, and a 3:73.
just a converter change and a gear swap the car should go 10.7 anyway, then more power from a motor cam, more compression ect ect. what do you think? and what are people running?
thanks guys
with a 4500+ stall, all motor cam choice, max effort n/a tune, and more gear it would easily run low 10's..
thanks for the other info guys. i think this is my setup for next season.
anyone interested in a bad *** N2O setup, let me know
fire away, if you want, go to pm's, im all for helping you out.
first off, just the cam selection alone is holding back huge power. cylender pressure is big.
also, heavy moving parts. the lighter the faster, but the heavy stuff is made for spray, made to take the shock!
also the tune up. running super cold plugs, low low timming, and very high octain kills a car unless your spraying. just the octain alone is huge.
117 in a motor car vs 112 or somthing will probably loose 5-10 rwhp do to the burn rate of the fuel.
anyway, i dont want to argu with anyone, i will just build it, and prove a point
Feel free to e-mail, call, or PM with any questions or concerns.
Trevor
Texas Speed & Performance
I dont have the nitrous hooked up to the car yet, but like yours, it's built for that, and also runs 11.00 on motor alone, @ a 3500 raceweight.
Trevor
im sure i will have to get the suspention diald back in, the car is setup to hook 1,000 rwhp on spray so im sure it will need some tweeking to hook 500 hp on motor. with a gear and converter.
what i want is a big wheelie car to make it fun, and a nice running car that wont need alot of maitnace.
im going to be light, im around 3200-3300 with all my nitrous stuff and the parachute. so loosing that stuff will drop me a good 60-70 pounds easy, so im sure with the converter, gear swap, and more HP the car will run well. hell, we have a low 10 sec 346 right now, so im sure we can ddo better
