etp LS7 heads & 408...anyone done it?
has it been done? is this the head of the pack? im still gonna F.i. the build, but i was wondering if they would benefit any. and maybe some results?
6 Second Club Moderator
It seems to work pretty good. I made just over 900 rwhp through a th400 on 17 lbs of boost and 18 deg of timing.
Originally Posted by Camaro_Zach
so im apparently an idiot...
et performance makes "ls7 heads" for a 4" bore? you can use em on say an ls2 block as opposed to having to have a 4.125 bore to use GM ls7 heads?
and does the GM ls7 intake bolt onto these heads?
Yes it does, that's what I'm using.
That's what she said...
Originally Posted by TheBlurLS1
What kind of pistons are you using? Are they custom for the valve angle? I wonder if 4.03" pistons with reliefs for 12* valves hard to come by?
Pistons had to cut a little, nothing big.
