Will L92 heads fit?
Old Sep 10, 2006 | 06:38 PM
Stang's Bane's Avatar
Default Will L92 heads fit?
Has anybody else noticed that L92 head threads are almost as numerous in here as "what cam should I use G5X3 or MS4" threads are in the LS1-LS6 section? NO offense to those thread starters, cuz I know that the search button don't always work. Just an observation....
Old Sep 10, 2006 | 08:51 PM
CTSmechanic's Avatar
Seriously if you think thats bad go to the gear section and read all the posts in there.... will my 10 bolt last can I build my own 9 inch? will the 12 bolt work... why are my gears noisy....
Old Sep 11, 2006 | 12:42 PM
I've noticed that as well. LOL
Old Sep 11, 2006 | 02:53 PM
cablebandit's Avatar
my search doesnt work here...i always get "408 timeout error" but it is fast on any other site...
Old Sep 11, 2006 | 03:25 PM
MrDude_1's Avatar
like any other tech site, alot of it is the same things over and over...
for example, on another site i frequent, you'll see a million posts asking how to land a double.
IMO, if you have to ask on the Internet, you shouldn't be jumping doubles yet. LOL.
EDIT:
double refering to jumping on a dirtbike.. LOL. i guess thats what happens when you jump back and forth between forums.
Old Sep 11, 2006 | 04:25 PM
BLKWS6's Avatar
well alot of people dont understand "bore sizes" and things like that. they just see a killer flowing head and a good price and need to know if it will work. you start throwing figures at them and its like chinese arithmatic to them....
Old Sep 13, 2006 | 12:06 AM
Nate_Taufer's Avatar
Can I spray a 100 shot at 60,XXX miles?
Old Sep 13, 2006 | 02:23 AM
Wnts2Go10O's Avatar
Can i use 2001-2002 exhaust manifolds on my 98?
Old Sep 13, 2006 | 08:00 PM
You know, the bad thing is that, they don't even recognize how badass it really does flow, all they see is the hype everyone is throwing at it. The reason I say that. is that I understood bore size way before I even had the slightest idea what head flow meant. There needs to be a way to make reading the stickies a requirement before asking questions.
Old Sep 13, 2006 | 08:05 PM
BLKWS6's Avatar
well that was my point....they could read the stickies and still have no clue...
Old Sep 13, 2006 | 09:14 PM
Maybe a test?
Old Sep 13, 2006 | 09:18 PM
Wnts2Go10O's Avatar
Originally Posted by Stang's Bane
Maybe a test?
the Sticky Before You Post quiz
Old Sep 13, 2006 | 09:26 PM
That is exactly right. Um, can we put this to a vote?
Old Sep 13, 2006 | 10:20 PM
Wnts2Go10O's Avatar
ill seconnd the motion
Old Sep 13, 2006 | 11:49 PM
Bring the Noise's Avatar
A cam for the L92 heads???
I would suggest not going with a LS1 based cam.
The size and flow difference between the intake and exhaust ports for a L92 head are closer to the LS7's design then they are a LS1.
A quick read up will tell you a large variance between the intake duration and exhaust duration makes the LS7 head produce the most power (something like 25 to 30). Something along the lines of a 228 intake and a 243 exhaust would probably be a good start.
The L92 head has a massive amount of flow/volume and medium velocity on the intake, where the exhaust is medium flow with a high velocity (well that is how I look at it).
Making people read the stickies before posting... that would take the fun out of the noobs.
Old Sep 14, 2006 | 08:52 AM
Did you read the rest of the thread?
Old Sep 14, 2006 | 11:26 AM
Wnts2Go10O's Avatar
he obviously did
Old Sep 16, 2006 | 02:50 AM
Cop Car's Avatar
L92 heads made the LS1 obsolete. when you can buy stock L92 heads for 800 bucks that flow better than $1200 ported 243s there is an issue... im mad i have an LS1 now, i want a 4.00 inch bore
Old Sep 16, 2006 | 08:16 AM
EPP's Avatar
EPP
Thumbs up
I foresee a 4.00" bore being the minimum in the very near future for performance builds. Remember when an LS6 454/450 in a Chevelle SS used to seem like a monster, how times have changed. We're heading towards huge power levels with these new heads. Bob
Old Sep 16, 2006 | 08:59 AM
Hell, no wonder people don't read the stickies, they don't even read the threads they post in
