L92 Combustion Chamber
Old Sep 27, 2006 | 01:21 PM
garrettpen's Avatar
Default L92 Combustion Chamber
What size combustion chamber do theese heads have stock?
Old Sep 27, 2006 | 01:37 PM
WKMCD's Avatar
Richard at WCCH measured it at 69.8cc.
Old Sep 27, 2006 | 01:42 PM
garrettpen's Avatar
Thanks.
Old Sep 27, 2006 | 04:46 PM
WKMCD's Avatar
I think when I worked the numbers for my motor, I came up with 11.17:1 compression on the 402 with 2cc pistons and .050 gaskets.
Old Sep 27, 2006 | 10:38 PM
SStrokerAce's Avatar
which for you means you gotta mill them puppies!
Old Sep 28, 2006 | 07:03 AM
WKMCD's Avatar
It's your cam we're going to run...
How much to mill? PM me if you want.
Old Sep 28, 2006 | 01:47 PM
garrettpen's Avatar
what would the cc size go down to if say you milled .030?
Old Sep 28, 2006 | 02:44 PM
Around 65cc
Bret
Old Sep 28, 2006 | 10:03 PM
JZ'sTA's Avatar
yep figure around 6-7 thous for every 1cc.
so 69.8 cc's minus 30 thousands should be close to 65-66.
Old Sep 28, 2006 | 10:18 PM
airflowdevelop's Avatar
there's plenty of flange on these heads....cut the pigs!!!
As measures with DcI seats (69.6cc) stock.
Old Oct 2, 2006 | 01:14 PM
garrettpen's Avatar
Thats a good rough formula to know, And milling that off you would still have enough clearance between the valve and the cylinder wall?
Old Oct 2, 2006 | 01:52 PM
See5's Avatar
In talking to some very knowlegeable guys who do work on these heads and manifolds for GM, it not clear yet that these heads are a slam dunk due to port size issues. They flow like crazy but they are truck heads. Not only that, if you start seriously milling the heads you can expect geometry, port match and manifold fit issues. Not to say they don't have big potential but-
