Is 500rwhp possible with a H/C LS2?
Old Sep 29, 2006 | 03:24 PM
LSs1Power's Avatar
Default Is 500rwhp possible with a H/C LS2?
I did a search and couldn't find an answer for this question. I would like to know if anyone been able to reach the 500rwhp mark with a H/C LS2. What heads and cam was used?
Old Sep 29, 2006 | 03:35 PM
98Z28MASS's Avatar
yes, and check in the dyno section as there are a decent amount fo guys that have hit that mark.
Old Sep 29, 2006 | 03:36 PM
98Z28MASS's Avatar
https://ls1tech.com/forums/removed-locked-thread-graveyard/583473-tfs-heads-402-550-a.html
Theres one
Old Sep 29, 2006 | 03:37 PM
98Z28MASS's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/560615-402ci-fast-90mm-afr-225-s-results.html
Old Sep 29, 2006 | 03:40 PM
LSs1Power's Avatar
Those are 402's... I was asking about a stock bottom end LS2 with only Heads and cam.
Old Sep 29, 2006 | 04:01 PM
LSX-Racer's Avatar
Banned - Ed Curtis aka EDC
2005 GTO
Old Sep 29, 2006 | 04:15 PM
98Z28MASS's Avatar
wait arent the ls2's a 402 block?
98Z28MASS's Avatar
or are they 364 or something like that?
Old Sep 29, 2006 | 04:26 PM
radz's Avatar
They are 364ci, and yes you can hit it but expect to spend some money on it. Someone else like Patrick G will chime in im, sure but some milled heads, flycut pistons, and a big cam on a tight LSA will make 500 with all the apropriate bolt ons.
Old Sep 29, 2006 | 04:50 PM
JZ'sTA's Avatar
The answer is simple.
You have a very similar motor as the LS1 with a LS2 with a larger bore which is good for HP.
There have been a few 500+ RWHP H/C LS1's so it is defentially possible in a LS2.
You will need the right combo and have some good change to spend.
A large cam like a G5X4/MS4/something similar that is around 240 degrees in duration with 11:1+ compression and every bolton need to be done.
Ported Fast, solid exhaust, very good air induction, a near perfect tune, and of course a M6 will be a much as the A4's eat up to much power for a dyno number.
OR you could do a solid roller setup and get there with with some to spare with the right setup. Not saying your stock LS2 will like being shifted that high.
Old Sep 29, 2006 | 05:04 PM
Quickin's Avatar
Its easy...all you need is cash and to expect it to idle like **** (for a daily driver anyway). Some love the lope. The torque will suck though. Stroke it a little bit and get both out of it.
Old Sep 29, 2006 | 05:51 PM
LSs1Power's Avatar
Im looking to achieve as close as 500rwhp with a cam in the 230 duration range. I don't want to go over that while keeping the compression in the low 11's range. The car is an M6.
Old Sep 29, 2006 | 06:15 PM
VENGEANCE's Avatar
The new TrickFlow heads are getting in the upper 400's with 230ish cams.... $2400 heads though.
Old Sep 29, 2006 | 07:24 PM
LSX-Racer's Avatar
2004 GTO - ETP215
Old Sep 29, 2006 | 08:03 PM
11 Bravo's Avatar
Don't get hung up on a dyno number, man. Just pick a good combo and have fun.
Old Sep 29, 2006 | 10:00 PM
Vengeance Racing's Avatar
LS1TECH Sponsor
Sent you a PM. IT CAN BE DONE no problem
Old Sep 29, 2006 | 10:13 PM
2scoot's Avatar
I'm there and a little more, assuming the dyno is correct of course. Yes it took money but it was more attention to detail.
Old Sep 30, 2006 | 03:51 AM
Utopia's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/499861-492-not-good-enough.html
This is my car runs pretty strong.
Old Sep 30, 2006 | 04:12 AM
Blown04Z06's Avatar
there is a C6 some where on here with running a t-rak cam, kooks 1 3/4, everything else stock hitting 450rwhp, so you would think AFR or ETP heads, ported fast 90, ported tb, under driven pulley, elwp and a strong tune would hit 500whp. maybe go to a set of LG long tubes & G5X4 and you can be there. LG put a C5 Z06 at 505 rwhp with AFR heads, fast 90, long tubes, pulley and a strong tune. totally possible but you would be taking the stock LS2 to the edge. why not just say F-it go with a 402 and make the power with out going to a max effort set up. thats what i decided to do, instead of rebuilding the LS6 and taking it to a max effort set up. after seeing what stock pistons look like, i wouldnt trust that the motor would last long.
Old Oct 10, 2006 | 08:35 PM
LA_Phantom's Avatar
There is a guy, Nick, out of Tampa with an '05 GTO who has made over 500 RWHP with heads/cam setup. The following is his basic setup:
Engine: HELLION Cam | ETP 225's | FAST 90 | Kooks LT's | Kooks Custom Turn-Downs | SLP UD Pulley | K&N CAI | P/P TB | SLP Thermostat 160º | NGK TR6 Plugs| DIY Catch Can
Formato Tune: 513RWHP 457RWTQ
