L92 and LS7 size?
Old Oct 12, 2006 | 01:01 AM
Payne's Avatar
Default L92 and LS7 size?
How many ccs are L92 and LS7 heads? I searched for a bit and all the terms are too short to get picked up...
If I have a 402 Iron Block with -18cc dish pistons, what compression would I have with both heads?
Im looking into a 'budget' turbo project and want to know what my head options are...
-Jason
Old Oct 12, 2006 | 01:04 AM
Wnts2Go10O's Avatar
the l92s are 69.8 and the ls7's wont fit your motor, int valves are too big
Old Oct 12, 2006 | 01:58 AM
jhong321's Avatar
-Jason
hey jason
with the L92 heads you should be about 9.2-1
check out this site
http://www.c5frc.com/calculators/Com...Calculator.htm
Old Oct 12, 2006 | 12:28 PM
SStrokerAce's Avatar
I hope with that compression your putting a blower on that.
Bret
Old Oct 12, 2006 | 12:33 PM
Payne's Avatar
Bret
Yup, thats the plan.... Im lookin to build a turbo chevelle.
Old Oct 12, 2006 | 02:18 PM
Ferocity02's Avatar
LS7's are 70cc
Old Oct 12, 2006 | 02:38 PM
Stang's Bane's Avatar
How much can you mill the LS7's. I heard the L92's can only go to around 66-67cc's comfortably? Someone please correct me if I am wrong.
Old Oct 12, 2006 | 05:52 PM
The chamber on the L92 is 70cc, and you can take it farther than that. The problem will be is you can mill them farther but at a point the intake manifold will not fit anymore.
Bret
