ls7 crate engine question...
Old Oct 19, 2006 | 10:47 AM
absolom's Avatar
Default ls7 crate engine question...
putting together a spreadsheet for an ls7
i have to have EVERYTHING
so far
this is what i'm coming up with
the "dressed" ls7 assembly from gm
this is what i'll have to get seperate from that
ecu
wiring harness
throttle body
alternator
ac compressor
ps pump
bell housing
clutch
oil lines
oil tank
motor mounts will be needed, as well as all bracketry i assume
what else is needed???
i'm assuming that there are some special flanges for the exhaust manifolds as well?
Old Oct 19, 2006 | 11:20 AM
absolom's Avatar
also, it'd be great if a sponsor could get me a price
Old Oct 19, 2006 | 12:43 PM
Project GatTagO's Avatar
so far
ecu
wiring harness
throttle body
alternator
ac compressor
ps pump
bell housing
clutch
oil lines
oil tank
The flywheel and the clutch are included with the crate engine. The throttle body is also included.
Andrew
Old Oct 19, 2006 | 01:27 PM
absolom's Avatar
Andrew
sweet, i wish i could find a site that gave some more concrete info on what actually does/doesn't come with the crate engine
Old Oct 19, 2006 | 01:34 PM
Do a search on all threads started by user John B. You will get links to a bunch of threads that detail the installation of an LS7 into his Monte. YOu will also find alot of useful answers and pictures.
Andrew
Old Oct 19, 2006 | 01:51 PM
GR33N GoblinM6's Avatar
yeah i think the thing that it doesnt come with.. is the dry sump tank and lines for it. If you choose to go with the dry sump system.. you'll need to relocate your battery and such...
there is a link on this board, Katech put an LS7 in an Fbody.. took some work as well. search for it.. is relatively new
Old Oct 19, 2006 | 02:17 PM
absolom's Avatar
i thought that all the dry sump stuff could be purchased from gm
and thanks a lot porject GatTagO, i found some great stuff by john b
talked to john spears at speartech and he answered several of my questions as well
Old Oct 19, 2006 | 04:26 PM
piusk's Avatar
the motor mount brackets and ex manifolds also come with it. lots of aftermarket dry sump tanks available.(good selection at speedway motors) use hose lines from local hose supplier.(1/5 the price and custom fit)
need an AN conversion fitting to attach lines to oil pan. wheel 2 wheel have them and i think street and performance. presently on ebay is a ls7 engine from fred beans parts, buy it now price for 12,395. good luck.
Old Oct 19, 2006 | 04:40 PM
absolom's Avatar
damn, that would be perfect
i've gotta see if our partner is ready to move
i also found a place that sells polished brackets and all the drive accessories, and spearteach has all the computer and harness related stuff
all that's left is the dry sump oiling stuff
i'll check out the speedway stuff, thanks
Old Oct 19, 2006 | 05:28 PM
c5racr1's Avatar
katech had to modify the stock z06 oil tank to work. I used a pegesus tank in mine. custom tank and lines are waaaay cheaper than the gm piece, only thing I wish I had was the dip stick!
Old Oct 19, 2006 | 05:42 PM
absolom's Avatar
i hear lokar makes a nice piece that fits
Old Oct 19, 2006 | 05:44 PM
absolom's Avatar
also, i'm desprately looking for an old link that i had, but can't find anymore
it's a place that makes a new front subframe for 1st gen camaros, it's not detroid engineering, but another place, and all i can remember is that the subframe was yellow
Old Oct 19, 2006 | 05:46 PM
BowtieSniper's Avatar
Hey man, I work at a Chevrolet dealership as the performance parts guy. If you have any more unanswered questions, I can call GM's Performance Division to get some concrete answers. Also, and just as important, I can even see if I can beat Beans price on the crate motor. I'll try to get that on here tomorrow.
Old Oct 20, 2006 | 03:40 AM
duke of cruel's Avatar
so far
ecu
wiring harness
throttle body
alternator
ac compressor
ps pump
bell housing
clutch
oil lines
oil tank
No bellhousing is included.
DoC
Old Oct 20, 2006 | 04:46 AM
absolom's Avatar
that would be wonderful!
Old Oct 20, 2006 | 04:47 AM
absolom's Avatar
DoC
ahh, what kind of bellhousing bolts up, the standard lsx bellhousing?
Old Oct 20, 2006 | 01:24 PM
Yes
Andrew
Old Oct 20, 2006 | 01:35 PM
absolom's Avatar
Yes
Andrew
excellent
Old Oct 20, 2006 | 05:17 PM
sorry if i missed this... but which generation camaro is this going in?
Old Oct 20, 2006 | 06:26 PM
absolom's Avatar
1st
i just got all my oiling questions answered by http://www.drysump.com/index1.htm
anybody have any experience with these guys?
they said they've supplied kits for around 12 ls7 builds
