414 L92 Long Block
Old Oct 23, 2006 | 10:41 AM
Mizfit MotorSports's Avatar
Default 414 L92 Long Block
Link:
I figured more guys in this section would be interested.
https://ls1tech.com/forums/lsx-parts-sale/592154-new-thread-414-l92-w-sheet-metal.html
Taylor
Mizfit
Old Oct 24, 2006 | 07:39 PM
accepting reasonable offers... only until Friday then goes to ebay.
Old Oct 24, 2006 | 10:12 PM
SSilverSSurfer's Avatar
damn i would be all over this, why so cheap?
Old Oct 25, 2006 | 08:30 AM
So I can be considered the most Badass sponsor on this board . Well because I need to move it to make room for the motor setup for our newest project car "Ouroboros".
Old Oct 25, 2006 | 10:16 AM
XJOSHX's Avatar
Will you take a kidney for it?
Old Oct 25, 2006 | 02:35 PM
Sure....
Old Oct 25, 2006 | 04:03 PM
XJOSHX's Avatar
Funny part is I am not joking, I'd really do it hahaha. Bump for a sweet motor.
Old Oct 28, 2006 | 08:49 AM
Will throw in covers and ASP pulley..Need this gone asap.
Old Oct 29, 2006 | 05:51 PM
Anonymous's Avatar
10 second playa
Here is a bump for trying.
The problem is the Iron Block.
9 out of 10 want aluminum for obvious reasons. (weight)
Cast Iron is for a max effort build.
This is a budget race motor and does not need an iron block.
It is just not worth the weight penalty.
The thin decks on the L92 heads won't hold a head gasket with a big shot or big boost.
Best of luck on your sale though.
Old Oct 29, 2006 | 07:09 PM
Well thanks for your opinion about the motor setup (We do build motors occasionally). Try telling that to everyone who owns a 408 I think they would most likely disagree with you. The choice for the iron block was one price. Second with some iron blocks if sonic tested can be bored out to 4.060 and still not lose its strength. We went this route to pull the most from the heads since this bore is closer to the L92 block bore. As far as weight penalty that is obvious but everyone who goes with iron knows that. As far as the thin deck yes you are correct but as you can see this motor was not built for forced induction. If one were to go with either of those setups they would be smart to select a different head anyways.
And yes it is a budget motor that is exactly why we selected the parts we did. We wanted 520-550 rwhp out of a budget setup and be a perfect street/strip motor.
Thanks for the bump anyways.
Taylor
Old Oct 30, 2006 | 10:01 AM
I am considering splitting up motor. I have a buyer lined up for the heads,intake and rails so if anyone is interested in the bottom half I will consider selling it. You would get:
414 iron block
Custom pistions : Diamond 4.060
Diamond pro select rings
New lifter trays
New oil galley plug
Comp Lifters
callies rods
arp main studs
arp rod bolts
Federal rod bearings
Federal main bearings
Clevite cam bearings
eagle crank 4 inch
Cam 246/253 .620 lift 112 Lsa
ported Ls6 pump
rollmaster dual roller timing chain
Let me know if you are interested.
Thanks
Taylor
Old Oct 30, 2006 | 11:45 AM
Inspector12's Avatar
TT-TECH Veteran
Well what are you asking for the short block with out the heads and intake etc...?
Old Oct 30, 2006 | 12:24 PM
Stang's Bane's Avatar
Damn, changing your mind again!!??
Old Oct 30, 2006 | 02:32 PM
$5100 for shortblock plus all other parts that are usually included in a longblock/complete motor.
Old Oct 30, 2006 | 03:24 PM
Sharpe's Avatar
Back off, I'll give him TWO!!!
There's always dialysis.
Old Nov 7, 2006 | 08:28 PM
bump......
