Will the L92 head/L76 intake combo render other H/C combos obsolete?
The L92 did not feature hogged out ports, it featured a head with a slightly smaller runner than the LS7 head. The intake runner was raised even moreso than the LS7
and featured very good flow even at lower lifts.
The head alone as it stood from the factory was good for 700HP or so N/A. With boost as far as you'd like.
The real question is how do the L92 head/intake manifold flow together as a unit.
The LS7 head alone does 360ish at max lift, where the LS7 head/intake does 320ish at max lift. Still better than any of the ported plastic intakes and ported LS6 heads.
"Gregfell" on this BBS ported the LS7 intake manifold, made some small modifications
and got the LS7 head/intake to flow 360ish at max lift with very little flow dropoff.
i dont care, when you can pick up a set of L92s for 800 bucks, and probably get ported ones for around $1500 it makes heads like AFRs pretty much obsolete. when you have the possiblity of making 500rwhp N/A with stock heads from GM, the aftermarket better get their prices down fast otherwise nobody will care that you can buy AFRs for $2000 that flow 351 CFM when you can buy ported L92s that flow 350 CFM for $1500
*Tard disclamer*: those are just random numbers made up to prove a point
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by SStrokerAce
This ain't just about flow/CFM fellas.... you are all trained to think that way but it's not what makes a cylinder head make power or get down the track faster. It's EVERYTHING.
Bret
Bret
Yep, the whole picture, Runner size, CFM, the velocity around the entire port and keeping a good average, etc. CFM only gets you a portion of the picture, and the power
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
LS1Tech Co-Founder
Keep in mind that aftermarket castings have other benefits than just CFM ratings. They are also beefier in areas that are prone to failure, have a thicker deck to reduce warping or lifting of heads, bigger spring pocket areas, taller valvecover borders, etc... So, they still have some nice advantages. CFM isn't everything.
That's what I would say too if the aftermarket head companies were paying the bills ;-)
Joking aside those are good points..... what BigBronco touched on is actually more important in terms of power. You can do other things in the design to help compensate for issues that a OEM casting gives you, and I've heard that the best blown setup one place has done to date was with the L92's. Only guys really pushing it like W2W with cylinder pressure will have the NEED for the super thick deck and rigid castings to keep the heads on the block.
Bret
Bret
Well, I was referring to a NA setup, so the casting strength issue isn't a factor to me specifically. I know that there may be better options, maybe my post should have asked the question, can any aftermarket head/intake combo match, on a HP/$$ basis, the potential of the L92/L76 combo in an NA application?
I'm eagerly awaiting some results on 4" bore motors, such as *cough cough* C6s. I am sure that ETP/TF/AFR combos are probably capable of matching and even outperforming this combo, but I'd like to see what a TEA/MTI/other porter here can do with a head that flows 320 cfm as cast. Once ported by a reputable porter, these ported L92 head/ L76 intake combos could potentially be signifigantly less expensive than the current aftermarket options.
That being said, I'm not gonna be a guinea pig, I'll wait for some real world numbers before I make a decision either way. As of right now, the ETP heads and the TrickFlow stuff is putting down some stout numbers, and are as of right now, the more proven commodity.
Shawn
Shawn
The L92 and LS7 stuff is great, it will be on many performance builds. The problem will come with those that need a more rigid platform. I look at material type and certain features that we require on certain builds. Both type of heads will have a place in our little corner of the internal combustion world!!
Kurt
Kurt
Bret
Bret
Kurt
Kurt
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
9 Second Club NA
Ok...seems like I'm in the same boat as the original poster. I'm VERY undecisive and just when I think I have a build put together, I read something new.
I can't decide between these setups:
LS7 block (read that block will be going down in price)
LS7 heads
LS7 intake
L92 block
Aftermarket LSX heads
FAST 90mm intake
L92 block
L92 heads
L76 intake
I'm not really on a budget, BUT, I don't have an unlimited amount of money to spend on this motor. I'm torn between a LS7 block and L92 block. Need to decide on that first, then I can decide on a head and intake combo. Either way I go, its going to have a minimum of a 4" bore as the L92 comes with a 4.065" bore and the LS7 comes with a 4.125" bore. What do you guys think would be a good combo that won't cost an arm and a leg, but isn't necessarily a budget build?
LS7 heads
LS7 intake
L92 block
FAST 90mm intake
L92 block
L92 heads
L76 intake
#32
Buy the LS7 427 Crate motor but change reluctor wheel to LS1 version so combo will work in your Camaro. You will also need cable version throttle body and bigger cam of course.
#33
Kleeborp the Moderator™
I know I'm pretty much retarded in this world, but I don't think the heads are the issue at all...it's the intakes. The LS7 intake sounds killer, but features a bottom-in opening throttle body that is very hard to duplicate functionality-wise on a cable driven TB. And now people are finally getting their hands on intakes that can fit the L92 heads, but no one knows how they will perform compared to a cathedral port intake. We have great flowing heads without the intake manifolds to match. And going sheet metal isn't the answer for a street car.
I guess I'll just sit idly by while the aftermarket gets this worked out. Maybe by the time I'm ready for a new engine, it won't be as hard to piece something together as it seems right now.
#35
Originally Posted by Wnts2Go10O
dont the LSx heads have an issue with too much velocity? (thats what i read from one of the more knowledgable people here) thats the reason why i would think these heads would out do the LS heads. comparing the 2 i see it as engineering the heads to slow down the air just enough to make that turn easier. granted, it flows amazing, has a massive cross section, humongous intake valves, and godly oem machining, but i think the magic lies in the short side more than anything else with these heads.
Bret
#36
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
