LS7 stock crank
Originally Posted by billreid1@***.net
Yes it can
Bill
Bill
and since the stock Lsx cranks have been run up into the 800's in hp levels with nodular iron...im sure the forged piece would be just as good with the new ones, if not better.
only problem being the longer snout though....hmmmmm.....
cutting the snout down..installing the wheel..plust the crank price. wonder if it would still be cheaper than an aftermarket? anybody know?
very well could be. i have no idea what the machine work would cost. i can just get a killer deal on that crank. maybe some of the shops/sponsors that can do it might post up about it.
I have 4.000" Cola cranks for $995. Close to the same price as the LS7 and just as good without the longer snout. Comes with the 24x trigger (not installed). If you want the trigger installed it's $35.
Unless you're requirements are a 4" stroke... I would seriously consider a stock 3.622 stroke crank. If 4" is a requirement lets put this to bed... pick up an Eagle crank and call it a day
just thinking out loud i guess
Originally Posted by garrettpen
whats a cola crank
A 4340 forged steel crank. Cola is not longer in business and we have a stockpile. It's a nice crank. There are people running over 1000hp with them.
Originally Posted by Louis
LS7 cranks have the longer snout, like Jason mentioned. Make sure you are aware of that before you purchase one.
yeah i was just thinking if the deal i can get on the LS7 crank + the machine work for the snout + swapping the reluctors would be less than going with an eagle/callies/cola/etc...
Nate
Originally Posted by Nate_Taufer
Why save 50 bucks and end up with a hodge-podge crank? Seems like getting a product designed for you application would be easier than butchering up some other crank. Just look at the Ford 8.8" rearend fiasco when people were trying to save a few hundred bucks by slapping them together with a mish-mash of parts. Turned out pretty nice right?
Nate
Nate
