LS7 oil pan adapter
For those of you wanting to adapt the LS7 dry sump system without using proprietary lines or the GM tank GM Performance parts now offers a billet AN-12 adapter for the oil pan. I've been waiting since April for this part to become available and it finally came in.
The kit contains the billet adapter, two bolts, two gaskets, and two AN-12 to straight O-ringed fittings. The part number is 25534412.
It should be just the ticket for a lot of us. I hope this helps some of you out.
There are many other changes you'd have to make to use the oil system on an ls1.
