TSP 402 runs strong
I know this kinda belongs in the drag racing section, but Im damn proud of my new motor
Nate
Thanks alot man, alot of hard work starting to show some rewards. Gotta love it.
Sounds like it's got a 9 second pass in her with the bottle pressure up where it should be! Get her to a 1/4 mile and let her fly!!
The MPH will pick up once you switch to the FAST and the headers.. What intake and header are you running now?
I can give you some tips... I noticed that you now have the NOS direct port.. That's the one that goes under each injector, right? They will NOT fit with the FAST intake. I know from experience.
When you get the FAST intake, you can drill & tap the intake while you have it off, add the burst panels, and put the new nozzles in. I have the part # for the nozzles that you will need for that kit, that will allow you to continue to use the same jets. I'll have to look for that, if you want it, or you can just call NOS & tell them that you want to make the switch, and get the #'s.
Port match the intake to the heads, and the TB while you have it off, & clean up the casting inside the intake. That will gain you some power. Or you can just purchase the intake from someone who can do all of this for you. I know that Futral will port match for the AFR, dont know about your heads. I'm sure they can also do the burst panels also. Or try Nitro Dave.
What are the specs on that cam?
