L92 heads flowing 374cfm & exh 250cfm
Old 11-13-2006, 11:15 AM
  #41
NemeSS's Avatar
everybody u talk to now a days in tx is a sam student or knows one
Old 11-13-2006, 07:15 PM
  #42
Nate_Taufer's Avatar
I think you hit the nail on the head.
Old 11-13-2006, 07:36 PM
  #43
Tuf-Titan's Avatar
"Inside scoop" well aint that some C.I.A ****.
Old 11-13-2006, 08:55 PM
  #44
Wnts2Go10O's Avatar
not to hijack further but... are you saying SAM is jus tan urban legend?
Old 11-13-2006, 09:08 PM
  #45
BigBronco's Avatar
Originally Posted by V6 Bird
check yourself at the door first...I doubt a student will admit their mistakes to you...BUt i have an inside scoop with the SAM boys...
Theres alot of "learning" mistakes in those heads...Ill let the good head porters notice the valve guide area on the intake side of things...
Mike I dont know if you talk to Casey Schneider or Brandon Frank, but they kept a very close eye on Cesar's progress with those things. Trust me, there were no messups as I saw these things come together.
I know you know Chris Frank as well as I. I am a good friend of his and trust me, he knows that if Casey will let them go and give the go ahead, they are fine.
Old 11-13-2006, 09:38 PM
  #46
Tuf-Titan's Avatar
Thank you BigBronco for giving him the heads up on these heads. Cesar is a good head porter and I trust his work.
Old 11-13-2006, 10:13 PM
  #47
02blutb's Avatar
i agree 100% he ported a set of heads for my brothers lt1 and they are all around better then lloyd elliot, trick flow and afr heads. they may flow a little less then some but when you average it out they are better all around. keep up the good work cesar and **** those haters
Old 11-14-2006, 09:53 AM
  #48
V6 Bird's Avatar
I havent shown the pics to Chris yet...But there are some obvious mistakes to me..Ill let Chris elaborate if he wants to...
Old 11-14-2006, 10:09 AM
  #49
UGotBeaT's Avatar
enlighten me please...........
Old 11-14-2006, 10:36 AM
  #50
TT632's Avatar
I had an set of conventional 18 degree heads on my vette that have similar peak flow #'s. 608 RWHP locked with a fairly flat torque curve. Those flow #'s, with compression, and a cam to take advantage of them should hit 600's.
  #51
VETTKLR's Avatar
V6Turd's problem is that there's an extra intake and exhaust port on those badboys, so he can't use them on his little motor.
Tuf-Titan, I'm glad you like your new toys! I got to hear all about them during the porting process, from velocities to flow #'s...they're gonna make serious power, no doubt!
Only if he gets a custom Jay Allen cam, huh Cesar
Old 11-14-2006, 11:12 AM
  #52
NemeSS's Avatar
Titan,
what exhaust valves are ugonna go with? u are not going to use the
stock 1.59's?
my heads flow way less than that on the intake,
but the guy (mikey s./SAM grad.) that is working
mine has turned down sodium ls6 valves to 1.615 for the exhaust
since they are goin on my tt 375 and i am using the stock 2.16 on the intake
but all he did on there was light short turn and bowl/valve throat work
nothing major but they picked up a few cfm all over from .200 to .600
Old 11-14-2006, 12:31 PM
  #53
Tuf-Titan's Avatar
Its up to Cesar on what he is going to do. He's going to be finishing them and I let him know that I was be going with a 4.125 bore block after all.
Old 11-14-2006, 12:59 PM
  #54
Tuf-Titan's Avatar
Smile
Whats going on with the carb intake? SDPC PM'd me saying they have them in stock right. So I give them a call and they tell me that the intake is not in stock nore they know when it will be in stock. Do any of you all know who has them?
Can you all tell me where I can get one of these? Thanks.
Old 11-14-2006, 01:21 PM
  #55
LS1Formulation's Avatar
There's L92 Carb intakes on eBay: http://cgi.ebay.com/ebaymotors/L92-I...QQcmdZViewItem
Old 11-14-2006, 03:22 PM
  #56
NemeSS's Avatar
where is that dude gettin them from?
i sa he also some l76's last week or week before that
Old 11-14-2006, 03:34 PM
  #57
V6 Bird's Avatar
ANd you are inserting your foot into your mouth by making outside assumptions on **** you dont know about...
V6 Bird is a decoy for the *** whooping you will get when you sit next to me on the strip. I assure you this "V6" Hits on all 8 cylinders.
Old 11-14-2006, 03:36 PM
  #58
V6 Bird's Avatar
Power is made by the shape of the port..I see that htere. BUt theres some flow chracteristics around the guide on the intake that could use some work to help direct it to the plug. If hes not finished then apologies are extended for sure. But my understanding at first glance that these were his finished purchase. Some port shaping irregularities are visable that could be easily fixed im sure too.
Old 11-14-2006, 05:54 PM
  #59
Tuf-Titan's Avatar
Thanks for the info on the intake.
Old 11-14-2006, 05:56 PM
  #60
UGotBeaT's Avatar
hmmm....and who are you to criticize my ports??? Im guessing your just going off what your buddy chris says cause I see absolutely nothing wrong with the vlave guide area or anything else...the port with all the bondo is going to be what the finished port is going to look like.
Quick Reply: L92 heads flowing 374cfm & exh 250cfm
