is the 454 ls1 Available for sale ?
Old Nov 15, 2006 | 10:01 AM
Houston999's Avatar
Default is the 454 ls1 Available for sale ?
how much is it?
Old Nov 15, 2006 | 10:06 AM
carado1984's Avatar
that block is sick.
Old Nov 15, 2006 | 10:36 AM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
Originally Posted by Houston999
how much is it?
The tall deck blocks will probably not be out until summer 07. I will see if I can get a more specific date.
Old Nov 15, 2006 | 10:56 AM
383ss's Avatar
that is not a '454'.
you can make a 454 with quite a few different bore/stroke combinations now. wet or dry sleeve. a shortblock is going to run you about 10k.
Old Nov 16, 2006 | 07:49 AM
Bandit28's Avatar
what is the stock bore and stroke on this block
Old Nov 16, 2006 | 08:50 AM
383ss's Avatar
there is no 'stock' stroke. you can put whatever you want in it. the tall deck takes up to a 4.5". the short deck is up to a 4.25 I beleive.
bore is up to 4.25.
Old Nov 16, 2006 | 09:55 AM
PSM's Avatar
PSM
oh to have money
Old Nov 16, 2006 | 02:19 PM
93capriceltz's Avatar
it will actually be around 3500
Old Nov 16, 2006 | 08:51 PM
LSX Wizard's Avatar
Funny.... the GM guys at SEMA were claiming it would be in the $2000 to $2500 range. You got some info they don't?
Old Nov 16, 2006 | 10:42 PM
Snyper's Avatar
that is a serious ******* block..wish they made stuff like this for LT1's
Old Nov 16, 2006 | 10:46 PM
Beast96Z's Avatar
You can build a 454 without the GM LSX block. I have a resleeved LS2 block, 4.155 bore x 4.185 stroke for 454 cubes. All aluminum, no extra weight. Cost was about $8k for the assembaled short block, no cores.
Old Nov 16, 2006 | 10:51 PM
SLED28's Avatar
Beast96z, I am building the same shortblock, A great way to get 454 cubes!! I'll be using a Katech LS2 block for this one.
Old Nov 19, 2006 | 02:55 PM
4U2BNVS's Avatar
In my new Hot Rod magazine they said it is going to be $2500 from them talking with GM
Old Nov 19, 2006 | 07:28 PM
Bill00Formula's Avatar
GM plans on doing a 454 LSX based crate motor per the article in this months hot rod magazine.
If the block isn't available I would guess the crate motor isn't either.
Old Nov 20, 2006 | 10:41 PM
black_knight's Avatar
Yes, in IRON. No basis to compare that to the aluminum block re-sleeves. Different animal.
