L92 heads with 1.8 ls7 rockers (pics)
Originally Posted by Dragaholic
The offset (slanted) rockers are the 1.8 LS7s and the straight rockers are the 1.7 LS1 correct? Can you run 2 different sizes?
Nate
Originally Posted by Wnts2Go10O
figured as much. o well, at least i didnt waste my money on something that wont work
So what rockers do we use on L92 heads? I thought the LS7's would work. Could you just run the LS7 exhaust rocker then? It would be nice to give the exhaust a little extra umph.
-Geoff
-Geoff
8 LS1 exhaust rockers and 8 L92 intake rockers with the Harland Sharp mod. That's what I'll be using on my L92 heads.
Nate
9 Second Club NA
Nate_Taufer, yes, I had planned on doing that to all 16 rocker arms.
Rock_Daddy, you might want to PM Nate at Nasty or call Harland Sharp directly. They'll probably have the best and quickest answer for you. Also, did you purchase a set of assembled L92 heads? If so, did it come with rocker arms? If not, how did you end up with an extra set?
Originally Posted by StreetnStrip
I had 2 of them laying around so I figured I would post them up being I know a few people was wondering if they would work. Do u guys want any other angles or do u need me to try anything else out?
theres really nothing worth trying on these heads yet. i would think that we could do the old hot rod ttrick of using diff ratio rockers... keep 1.7 stockers for the intake and use aftermarket 1.8s for the exhaust.
Originally Posted by GIGAPUNK
Is there any reason that the 1.8s won't work in the exhaust?
