L92 head dyno in GM High Tech
Old Dec 4, 2006 | 05:01 PM
  #61
BAD2000TA's Avatar
Originally Posted by dhdenney
Not big enough.
Is that what she said? Sorry to hear that!
Old Dec 4, 2006 | 07:54 PM
  #62
S1LV3R's Avatar
Is this the Feb. issue?
Old Dec 4, 2006 | 09:03 PM
  #63
SStrokerAce's Avatar
Originally Posted by LSX Wizard
Curious why you'd claim the Ti LS7 valves are a liability? Del West makes them, and they are certainly well known in the aftermarket world for Ti valves! Please explain.
Well there have been a lot of instances where the hard tips have come off of the stockers and caused hell in the motors. I know about every shop that works with LS7 stuff regularly has gotten bit by it before.
Bret
Old Dec 4, 2006 | 09:13 PM
  #64
MUSTANGEATER's Avatar
Bret
Werd don't forget that stock LS7 valve job.
Old Dec 5, 2006 | 05:09 AM
  #65
S1LV3R's Avatar
Anyone?
Old Dec 5, 2006 | 05:29 AM
  #66
Quik's Avatar
Originally Posted by Quik
i just read that article and it is suprising that they only had a 4* spilt where as the net is saying a 10* spilt is in favor. but looking at the graph the cam they used made some good numbers on a 6.0. makes you wonder if a typical ls cam could still be used to make good power
TTTTTTTTTTTTTTt
Old Dec 5, 2006 | 08:23 AM
  #67
GIGAPUNK's Avatar
Not big enough.
Then upload some higher res scans. Or save it and zoom.
Those were all the pixels I had to work with.
On another note... I calculate a 7.5 degree split, off of the given head flows. And those flow numbers have worse exhaust flow than what I've seen posted elsewhere. And with the headers that they are using in a dyno room, I'm sure that left a bit on the table, but how much?
Old Dec 5, 2006 | 12:28 PM
  #68
dhdenney's Avatar
Easy killer. I wasn't trying to be an ***. I tried saving it and zooming but it's all distorted. I merely indicated that one couldn't read it so that maybe the others viewing this thread could get a larger image. I'm sure the data is good but I can't read it. If I had the mag I wouldn't have ask for a larger image. Gees.........
Old Dec 5, 2006 | 07:03 PM
  #69
LSX Wizard's Avatar
Bret
I think it's got a lot more to do with the valvetrain dynamics, not the valves. Lash caps have been used for years and years, however, usually in solid cam applications. I would say that improper valvespring selection (not enough pressure/pressure rate), coupled with hydraulic roller lifters and the engine being over-revved causing valve toss and bounce, thus dislodging the caps and causing damage.
Old Dec 5, 2006 | 07:22 PM
  #70
LS2 Pontiac GTO's Avatar
Does anyone have any idea why the L92's in the GM article made so much more power? There intake runner size is I think 260cc. From what ive heard that is way to much for a stock displacment LS2. Also the stock L92's drop the LS2's compression.
So is it just a matter of the L92's simply outflowing the LS2's heads?
Old Dec 5, 2006 | 07:33 PM
  #71
66deuce's Avatar
i guess it show's there's more to a good set of heads than just runner volume...
Old Dec 5, 2006 | 07:39 PM
  #72
GIGAPUNK's Avatar
Any thoughts on what is causing the strange dip in the power curve on the L76 motor?
Old Dec 5, 2006 | 08:04 PM
  #73
ChucksZ06's Avatar
Getting the air in the cylinder is more important than how it is accomplished. If the larger port is more efficient then you can make more power than a smaller less efficient port. There is a lot of misinformation on this forum about "high velocity" ports being necessary to make good low end torque (true up to a point). These heads allow a straighter shot into the cylinder than the cathedral port heads and the extra width up high is where the air wants to flow. I do not think GM would have mass produced a head that had poor low end performance when it has to haul around 3 ton vehicles (truck motors).
Old Dec 5, 2006 | 08:37 PM
  #74
fourplay's Avatar
Good point ChucksZo6!!!!!!!!!!!!!!!!!!!!
Old Dec 5, 2006 | 08:50 PM
  #75
So it is pretty much all about flow
Old Dec 5, 2006 | 09:21 PM
  #76
On 3 Motorsports's Avatar
Is this something GM offers out of their high performance catalog?
I can't believe how affordable the L92 cylinder heads are!
Old Dec 7, 2006 | 07:31 PM
  #77
HTMtrSprt's Avatar
..... I do not think GM would have mass produced a head that had poor low end performance when it has to haul around 3 ton vehicles (truck motors).
Why not??..... they've been doing it for years.......
Old Dec 7, 2006 | 09:45 PM
  #78
Irocss85's Avatar
so what month magazine is this article in?
who's got part #s for these heads, and who's selling them at that price? GM dealers to public? someone mentioned an adapter to fit a 90mm TB, who sells that adapter? do those heads fit LS1's? or are the valves too big for the LS1 bore?
Old Dec 7, 2006 | 10:00 PM
  #79
JakeFusion's Avatar
Super Hulk Smash
Too big for the LS1 bore - requires a 4.00". SDPC is selling them and the L76 manifold as well as TSP. I'm sure you can buy them through GMPP - the sticky at the top of the LS7 Performance section has all the P/N's... including the offset rockers needed.
Also, any 4-bolt 90mm cable-driven TB will work, such as the Holley, UMI, or Nick Williams. Holley includes the adapter, and I believe Katech sells it outright.
Old Dec 7, 2006 | 10:41 PM
  #80
Irocss85's Avatar
these are exciting times were living in indeed. makes me want to sell my LT1 stroker, and build a big inch LSx. ahh, one day.
