LS2 402 with headers stock heads and intake?
Old Dec 27, 2006 | 05:49 PM
firebird6786's Avatar
Default LS2 402 with headers w/LS1 stock heads and intake?
a LS2 402 short block, Im putting it in my 94 transam.these heads are off a LS1 and so is the intake. The goal is just to get the motor and everything else to convert it in the car and running. I will be waiting for a little while before i can get heads and intake. what am i looking at for horsepower and torque?
Old Dec 27, 2006 | 10:08 PM
DoesSpeedTurnUon's Avatar
if you're going to goto that much trouble putting an LS2 stroker in, go ahead and get the L92 heads and the L76 intake with a custom cam, and be done with it. Do it one time, rather than twice.
Old Dec 27, 2006 | 10:20 PM
03 BUSA's Avatar
I agree the L92 heads can be had very cheap and the complete intake only costs $450. As far as a stock LS2 in your car with LS1 top end I would think somewhere in the low 300rwhp. With a set of those heads and intake with a decent cam you could be well over 400rwhp for alot less than you think.
Old Dec 27, 2006 | 10:25 PM
you could probably make a little more than that with a 402 and an LS1 top end, depending on heads.
With a STOCK LS1 cam/heads in a 402 you could probably make: 350-375rwhp
Same Stock Cam, with L92 heads, maybe 380-390
But... put a REAL cam in a 403 with L92 heads (untouched) and L76 Intake... 500 easy.
BTW, where are you seeing an L76 intake for $450? Scoggins sells them for $528
Old Dec 28, 2006 | 10:07 AM
no, its a LS2 402 stroker and im using stock LS1 heads and intake for now. wanna get a ball park on HP's and touque. just really trying to get the motor in and running, then worry about heads and intake later on.
Old Dec 28, 2006 | 04:04 PM
Stang's Bane's Avatar
If you plan on using the stock cam I would say about 350-360 hp and 390-400 tq. Why not pick up a used cam about a 230 or so and up that to about 400 hp or so? If not more.
Old Dec 28, 2006 | 04:19 PM
https://ls1tech.com/forums/lsx-parts-sale/631182-cam-sale.html
Old Dec 29, 2006 | 11:44 AM
im going to get a cam for it (nitrous cam) run a 150 shot to it later on.you thinking 400 or so at the wheels?
Old Dec 29, 2006 | 11:50 AM
Unless you are running more than a 250 shot, don't worry about the nitrous when you are picking a cam.
