FAST w/LS6 vs L76 w/L92 on a stroker
Originally Posted by Beast96Z
I can only assume your running a stock LS2 block with a 4.100 Eagle crank. In this instance, I would wait around awhile before i went with the L92's on a 4" bore. While magazine articales are nice, I don't lay alot of claim into them. These heads/intake are still very new to the market, and finding a cam that will work will also be a fun challenge. I'd wait for a few vendors to complete some testing on diffrent bore sizes and camshafts before you dumped your current combo. A ported FAST and a nice set of ported LS6's should easily make great power. If your chasing gremilin, get those worked out before you swap anything. Details on the motor would also be nice. (cam size, power, etc...)
Unfortunatley we will see cam specs flying around here soon and everyone will jump on the bandwagon. Another reason why we have soo many internet know it alls yet none producing any respectable et slips to back up their knowledge.
Originally Posted by Forteen3GT
also I havent seen your curve.... 535rwhp with 26 degrees is good power..... but at what cost? what is the compression? I always thought that that much timing and those LS6 heads you would be needing non pump gas?? Am I off on this assumption?
Originally Posted by V6 Bird
Its not finding a cam to work with them, its finding a builder who can take your heads and rotating assembly and grind the cam to do what you want it to do. Max effort or daiyl torque monster etc. Bret Bauer I believe had his hands on a setup like this recently and produced what the customer wanted...
his heads flow 305cfm..... stock untouch L92's flow 330cfm with no work. .
I think ALOT of people forget that regardless how many billion cfm your heads flow- that you are INTAKE LIMITED: which is one of the MAIN reasons I sold my ported 90/90 and AFR 225'S and went L92/L76.....
with a manifold ATTACHED these heads flow more than MOST GOOD Lsx heads do by themselves.
https://ls1tech.com/forums/generation-iv-internal-engine/602800-l92-flow-results-manifold.html
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I think one of the main benifits of these heads/intake are it allows you to use a lot less cam and achieve the same results as we were used to previous to these heads being released.
If you WANT more power.... im sure you can go to a cam similiar in specs and gain more power if you wanted........ But if you were content (are we ever?) with your current power levels... I'D BET: that you could spec out something considerable smaller, and STILL have the same numbers you currently have (not to mention alot more drivibility imho)
https://ls1tech.com/forums/showthread.php?t=602800
Considering an aftermarket valve from Rev is available... I would send these heads to someone like Huttos friend Chris or another SAM graduate (preferably someone with experiance in old school small blocks with hydrolic cams, since the I:E ratio is closer to that of an old school engine).....
Good luck!
LS1TECH Sponsor
Sorry for the rant, I just took it the wrong way. When he said 414, I automatically thought of the LS2 combo's since most of them come in that cube range. You don't see to many people with .060" over iron blocks, so it was the farthest thing from my mind. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by jeremym
The L76/L92 stuff is to new to get all the info I want. Really nobody has before and after dyno charts if they do please post them
Like I said earlier, your numbers now are outstanding. Let a few people, like TSP and WCCH, finish up their CNC programs and then we will see some ported L92 results.
I say that because my porter aka Chris has already seen 370+ in R&D with about an hour of bowl work and a good valve job. Hasnt done anythint with the exhaust yet.
#37
I don't think he was talking about your power.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
#38
What prelim numbers are you reffering to that are weak in your opinion?
#39
I cant speak too loud about them, because they will cry. Ill let you make your own assumptions.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
