L92 crankshaft
Old Feb 9, 2007 | 11:58 PM
Tom@SpeedInc's Avatar
Default L92 crankshaft
Anyone know the difference between
GEN III 5.3-5.7-6.0 crankshaft part number 12559354
L92 6.2 crankshaft part number 12584997
Other then the reluctor ring are these the same crankshafts?
ty
Old Feb 10, 2007 | 01:25 AM
DoesSpeedTurnUon's Avatar
I was told they're all 3.622 stroke. different bore sizes for different motors.
Old Feb 10, 2007 | 09:06 AM
Karlo's Avatar
I was wondering the same thing? The Price is hard to beat also?
12584997 GM Performance Crankshaft Assembly 2007 L92 $220.97
Old Feb 10, 2007 | 09:26 AM
bg-sdpc's Avatar
LS1TECH & Trucks Sponsor
ty
The only differences are the reluctor ring and that they are balanced differently because they have different bob weights. If you are building a custom engine with one of these cranks it will not matter which one you use because it will be rebalanced to the new parts. Just make sure you have one with the correct reluctor.
Old Feb 10, 2007 | 11:31 AM
WizeAss's Avatar
I thought the L92 engine had a forged crank??
Old Feb 10, 2007 | 12:15 PM
bg-sdpc's Avatar
The original press release that came out said they were forged but they are not. It is a standard cast crank.
Old Feb 10, 2007 | 03:47 PM
99Fbody99's Avatar
Beside the balance weights the truck crankshafts are not gun drilled for weight reduction.
Dave
Old Feb 10, 2007 | 04:28 PM
the LS1 crankshaft was nodular iron (iirc) is L92 crankshaft likewise? or weaker?
Old Feb 11, 2007 | 06:54 PM
big b's Avatar
So what relucter ring does the l92 crank come with? Looking at possibly building a mild street engine with this crank. And the price is almost too good to pass up. Is it the same as any other gen3 truck engine? Are there any reasons not to use this crank? "hp/tq limits"...
Old Feb 11, 2007 | 09:50 PM
chris.shea's Avatar
Why not stick with a stock(proven strong)? any reason gm is casting new cranks if they all have the same throw?
Old Feb 12, 2007 | 11:16 AM
NO-OPTION-2002's Avatar
it's cheaper to build a few specific cranks than to balance each individual engine.
