T56 in 6.0 Iron Block?
Old Feb 11, 2007 | 06:30 PM
1999ssls1's Avatar
Default T56 in 6.0 Iron Block?
Has anyone done it? Im wandering if the cranks are the same size as ls1s. I cant get my clutch lined up or it may just be something different about the blocks.
Old Feb 11, 2007 | 08:06 PM
SUTTERERMAN85's Avatar
depends on what year 6.0L. if it had alum 317 heads then yes you just have to take the adapter off. if its an '00 and down then no it wont work you need a different crank.
Old Feb 11, 2007 | 10:08 PM
Quik's Avatar
i know my old 03 6.0 works fine with a t56
Old Feb 12, 2007 | 07:11 AM
1999ssls1's Avatar
mine wont go in the crank far enough. Do they make a special flywheel
Old Feb 12, 2007 | 07:49 AM
digitalsolo's Avatar
The only way a 6.0 wouldn't fit would be the 99/00 motors with too LONG of a crank. If you're having issues a la too short of a crank, you'e doing something wrong.
What exactly won't go into the crank enough?
If you do have the long crank motor, you will need to change cranks, or adapt an LT1 T56 to fit.
Old Feb 12, 2007 | 07:57 AM
98Z28CobraKiller's Avatar
Restricted User
Need more info. What did the 6.0 block come out off?
Old Feb 12, 2007 | 10:17 PM
1999ssls1's Avatar
I think a 99 2500 pickup truck
Old Feb 12, 2007 | 10:19 PM
1999ssls1's Avatar
Could I just put an lt1 flywheel on or bellhousing?
Old Feb 12, 2007 | 10:28 PM
Pwebbz28's Avatar
Nope but if you need a stock ls1 crank i got one you can have for $100 if you are in DFW.
Old Feb 12, 2007 | 10:30 PM
1999ssls1's Avatar
will the ls1 crank work?
Old Feb 12, 2007 | 10:35 PM
Pwebbz28's Avatar
Yes it sure will.
Old Feb 12, 2007 | 10:39 PM
1999ssls1's Avatar
will an lt1 flywheel work on an ls1?
Old Feb 12, 2007 | 11:32 PM
Not for what you're wanting to do.
An LT1 T56 would have the correct spacing for your long crank motor, and wil bolt up to the block, but I'm not sure what you need as far as clutch/flywheel combination. If you can swap parts around between LS1 and LT1 clutches and flywheels, you could in theory use the LS1 clutch/flywheel with the LT1 T56 if the input shaft fits correctly. At this point swapping cranks might be your easiest route, assuming you can handle the labor portion.
I'm an automatic guy for my LSx motors, as I tend to gravitate towards straight liners, so others may be able to go into more detail on this.
Old Feb 13, 2007 | 08:09 AM
1999ssls1's Avatar
will the 6.0 main caps work on the ls1 crank?
Old Feb 13, 2007 | 08:24 AM
Wong's Avatar
It should work fine with all LQ9's right?
Old Feb 13, 2007 | 05:00 PM
1999ssls1's Avatar
its a 99, so its a lq4
Old Feb 13, 2007 | 06:38 PM
Caps should be fine.
