L92 DynoJet Numbers Plus Plan B, C, D, E and F...
Old 07-24-2008, 10:13 PM
  #461
JoeyGC5's Avatar
Cool, thanks for comtinuing the updates.
Old 07-24-2008, 10:45 PM
  #462
Suaveat69's Avatar
Originally Posted by WKMCD
This is a great tool. I used is a bunch when specing cams. Just plug in the numbers.
http://www.alantripp.com/VE%20calcul...y%20Lookup.xls
Thanks for the link!
Old 07-24-2008, 10:52 PM
  #463
10 & 11 Second Club
Caveman's Avatar
Nice looking Vette, no wonder you dont dragrace it.
Old 07-25-2008, 12:04 AM
  #464
Richard@WCCH's Avatar
Cam swap, eh?
I admire and appreciate your never quit attitude sir.
You're in great hands for sure.
Good luck chief.
Richard
Old 07-25-2008, 06:55 AM
  #465
veee8's Avatar
Glad to see this thread still going. The day I saw the pics of the CNC Stage 2 WCCH heads, is when I sent my L92's to Rich for the same treatment! Can't wait to see how Ed makes out this round!
Here is a little taste of a WCCH intake port!
Old 07-25-2008, 11:14 AM
  #466
2c5s's Avatar
Originally Posted by edcmat-l1
Time to bring it back.
This round of mods. Call it plan C?? We'll let Kevin decide.
This months round of mods include a cam swap (go figure) springs, clutch pedestal inserts to quiet the dual disc down. Wideband wired into the PCM with narrow band output.
99+ PCM swap. Dont let no one fool ya on the complexity, or time it takes.
Cam swap is done. PCM swap is done. No to make it run. Hopefully dyno numbers tomorrow. I would think Saturday by the latest.
Looking forward to seeing the new results!!!!!!
Old 07-25-2008, 04:28 PM
  #467
edcmat-l1's Avatar
Default Lessons learned
Never take anything for granted.
Case in point. Repinned the PCM connectors to the TEE. Was very careful labeling, swapping, double checking the whole way. Flashed the PCM with the 02 OS. Hit the key, and have all kinds of popping from the tail pipes. Just like crossed plug wires.
Recheck everything, all pins are where they are supposed to be.
Now, for the curve ball. This car has the coil relocation mod. Plugs wires were not disturbed.
So, break out the trusty old o-scope, set it to trigger off an injector pulse. Set channel 2 to trace the secondary ignition. This will give me a good view of when the coils are firing in relation to the injectors firing. I scope a good cylinder to get a base line.
Go to the passenger side, probe #2 injector and plug wire. The plug is firing at the same time the injector is spraying. NOT the way it was meant to be.
So, while still on #2 injector, I start probing the other plug wires, til I get one that is firing at the right time, in relation to the injector. Turns out its #8 coil.
Then on to #4, again the plug firing did not end up where it needed to be.
Long story short, I had to swap the 2 and 8 coil drivers, and 4 and 6. I imagine that the harness extender for the coil relocation is pinned wrong. When the car was built, they probably just swapped the plug wires. We will put the coil driver wires back where the need to be, and put plug wires on it. They are too short to stretch.
So, moral of the story, dont take anything for granted. When diagnosing a problem, step back and develop a game plan. This could have been a real *** beater.
All in a days work
Old 07-25-2008, 05:22 PM
  #468
WKMCD's Avatar
And you expected it to go smoothly and as planned???
I do know a number of people using those harnesses without problems.
This is why - you da' man!
Is it too late just to put the car back to stock???
Old 07-25-2008, 05:29 PM
  #469
edcmat-l1's Avatar
Say what??????
Old 07-25-2008, 05:35 PM
  #470
WKMCD's Avatar
Say what??????
I thought it was stock.
Old 07-25-2008, 06:27 PM
  #471
Phil'sC5vette's Avatar
Nice work Ed.
I would have given up by now.
I would have bought a new ZR1, cut the roof off, and yes kevin have a step back in performance lol
Im glad I never modified my car.
Did I read in one of the threads you switched cams again ? It's not winter yet
Old 07-25-2008, 07:57 PM
  #472
veee8's Avatar
Still planning on dynoing it on Saturday?
Ed's experience sure pays off in a situation like this. Great job!
Old 07-25-2008, 11:02 PM
  #473
hymey's Avatar
Going bigger in the cam Kev? How much hp you chasing? Look forward to the results.
Old 07-26-2008, 06:18 AM
  #474
WKMCD's Avatar
Actually, this cam is smaller in some respects and larger in others. Let's see how it works. Not really chasing a number...just trying to see what can be done.
Old 07-26-2008, 06:14 PM
  #475
veee8's Avatar
Any news today????
Old 07-26-2008, 06:20 PM
  #476
WKMCD's Avatar
Originally Posted by veee8
Any news today????
Not yet. I'm not bugging Ed. Maybe he'll post something this evening.
Old 07-26-2008, 09:12 PM
  #477
1ORANGEWS6's Avatar
Can't wait to see the new results. I have been following your build for a while. Will you be changing the cam once a new L92 intake comes out?
Old 07-27-2008, 03:33 AM
  #478
WKMCD's Avatar
Probably not. I think this cam somewhat allows for what we think the new manifolds will want.
Old 07-28-2008, 03:55 PM
  #479
Cobra4B's Avatar
geeze... can't you leave it alone Oh... my car is done soon... then I'll be knocking on you door one Sunday AM for some golf!
Old 07-28-2008, 09:04 PM
  #480
WKMCD's Avatar
Anytime Brian.
I talked with Ed today. He was going to replace 3 of the stands in the RAM DD clutch with the new style composite type but found out that the studs are not studs but through bolts from the engine side and would require dropping the pan or dropping the torques tube back. I told him to hold off on that. The car is running and he's still tuning. The new plan is to pick it up Saturday so Ed has time and miles to perfect the tune - that's the whole purpose of the new PCM.
Quick Reply: L92 DynoJet Numbers Plus Plan B, C, D, E and F...
