L92 heads on a LM4?
Old Feb 23, 2007 | 09:57 PM
jgonzales's Avatar
Default L92 heads on a LM4?
I might be building an engine soon for my RX-7, I'm still tossing around ideas though. I recently found out about the LM4 engine, all aluminum truck engine that came in small SUV's. From what I understand it's the same design as the LM7, so can it be bored? If so, how much? Would it be possible to bore it enough for the L92 heads to work? I've searched, but there isn't really a lot of info on the LM4. I know the LS2 would be a better choice, but I'm trying to stay in a certain price range... thanks in advance for any help.
EDIT: If this should be in a different section of the forum, I'm sorry. I thought this would be the appropriate place to post...
Old Feb 24, 2007 | 03:42 AM
vortec_7's Avatar
quick tidbit: LM4 is ~ as costly as an LS1.
Get the LS1.
LM7...not as costly, but iron block/Al heads
Old Feb 24, 2007 | 06:22 AM
Bring the Noise's Avatar
Hmm Wiki wiki lists the LM4 as a 5.3L.
L92 heads would work only if the block can be bored out to a 4.000" bore (or larger).
Old Feb 24, 2007 | 06:01 PM
jgonzales's Avatar
Get the LS1.
That's what everyone else has told me, but I've found several in my area for $1-2k with VERY low mileage so I'm looking at this as an option.
Old Feb 24, 2007 | 06:03 PM
jgonzales's Avatar
Yeah, I read all the info on there about it. I knew it had to be bored to 4.0" to use the L92 heads, but that was my question... can it be bored that much?
Old Feb 24, 2007 | 06:50 PM
NoGamesLS1's Avatar
Not an aluminum block. It will have to be resleaved. I would just get a lq4/lq9 or a ls2 block
NoGamesLS1's Avatar
resleaving=$$$
Old Feb 25, 2007 | 03:59 PM
jgonzales's Avatar
Originally Posted by NoGamesLS1
resleaving=$$$
Ok, that's just what I wanted to know. I didn't know if it had to be resleeved or not. Thanks!
