414 with l92 heads
edit: nevermind that was a stupid question. its just a 6.0 bored .06 over with 4.00 crank and 1.25 rod
I too would like to see flow data with L92 head and intake setup.
Richard
Richard
http://www.gmhightechperformance.com...ine_l92_heads/
The big ugly flow numbers are actually pretty good on the Vortecs, better than the LS1 intake.
obviously you didnt read or understand the article you just posted the link to.
This is incorrect?
Understood from Holden K. I see big ugly still exists with rectangular ports.
This is incorrect?
L92= intake being used on trucks
L76= intake being used in place of L92 due to limited space
Use the 4.125" crank with this block, nice price.
What 6.0L block are you referring to LQ4 or LQ9? GM squaks about the wall thickness being maxed. Guys here have gone larger. Do a search, but the L92 is the answer for the money.
Yes you can as I had this exact same type of motor built for me by a tuner here 5 years ago. Just make sure the complete motor is BUILT by somebody who REALLY KNOWS what they are doing or you could have issues like i did with oil consumption and even my Callies 4.125 crank failing (but the crank issue should be a non issue for you) as long as the engine is built by somebody who really knows what they are doing.
You also need to get the ironblock sonic tested to make sure there is proper strength and cylinder wall thickness if she is getting bored out to 4.060!
You are better off in my opinion sticking with a 4 inch crank for 414 cubes as i believe the motor will last longer from a longevity standpoint, will use less oil and will have room left over in the cylinder walls for a rebuild if ever necessary! 4 inch stroke has the best track record on LS series motors and that is why you see companies lik KATECH sticking to 4 inch strokes in their motors built for GM RACING!
Also, if you are planning to stay N/A i would stick with an alum. LS2 block or L92 block posted above for less weight restriction, etc.!
