Found a Problem, Engine Builders Check out these Pics
Can I get some of y'alls opinion on this? What do you think the problem is, if you were the vendor what would you say? If the vendor does not stand behind their work, how long do you think this is going to last? (I'm going to have to save money for another motor, I'm having a pretty bad last few months here). Maybe I can get a bunch of comments together to show the vendor. I've already had 3 mech's look at it and they all agree with my diagnosis, maybe I'm just looking for some more support.
I don't want to give these guys any bad press yet because I'm still not sure where they stand. Like I said this vendor has always been awesome and I've backed them countless times when folks are asking where to get a good shortblock. Maybe the machinist just had a bad day, or maybe the pistons were a bad lot. What do you all think? I'll take some better pics in the daylight but here are some quickies.
TSP has been very good about this. I can't see them trying to blame this on me if its not my fault. Seems like the poster has a beef with TSP. I didn't and most certainly do not now. I originally wanted to know if anybody else thought it was an issue worth pursuing and I was convinced it was. I was erroniously led to believe TSP didn't want to look at the issue and only mentioned them as a "vendor" until somebody else brought up their name. But, it all worked out cause they very much want to get this right and make sure everybody knows their builders are top notch.
The short-block was purchased from us here @ TSP. When I talk with the owner of this engine I'll setup a time to get it back to us for inspection. There's many many issues that could be causing this, so attempting to blame the builder prior to researching it is absolutely ridiculous. It's really disturbing how many people are trying to discredit a vendor without any facts or information. We have hundreds and hundreds of short-blocks in use, and it's for a reason. Our quality and reputation speaks for itself, so trying to insinuate that we're building junk is pretty laughable.
We sell and ship hundreds & hundreds of engines every year without any issues. The machine shop that machines & assembles our engines build everything from our LS-based engines up to PRO STOCK engines! It's common practice for us to see $50K+ engines sitting on the dyno or being built right next to these LSx engines! The majority of their engines are built and sold for NHRA racers.
Rest assured I'll personally make sure that if there is any issue whatsoever that was caused on our end that it's fixed immediately. That being said, some of the people in the thread questioning the quality of another vendor's short blocks is incredibly shady. We're not selling engines on eBay where we won't be around next week to take care of the customer. We don't sell the volume we do because of lack of quality, know-how, or customer service.
We don't slap an engine together and hope for the best. We have a build sheet on every engine, and every engine does not leave until it's right. From bearing clearances to ring gaps, our engines are built with only the best procedures. Charging an arm and a leg for an engine doesn't make your quality that much better. It just makes your prices high-end.
We're able to build these short-blocks quickly & without issue because at any point there may be as many as 8-10 people working on LS-based engines in an effort to ship quality products in a timely fashion. We build multiple short-blocks to try and keep some in stock at all times. Being our busy season, we cannot keep more than eight or ten short-blocks in stock at any point. At any other point during the year, it's not uncommon at all for us to have 15-20+ short-blocks built and ready to ship. Having the resources to build a lot of engines and have some in stock does not make our engines questionable.
If you guys want to question someone's short-blocks you might as well get in someone else's thread. We're going to get the short-block back from the customer and go through it for him. So, all of the other engine shops that are desperately trying to get the engine to discredit another vendor can go elsewhere.
Run a quick search on ls1tech, & you'll find we probably build more short-blocks on ls1tech than any other vendor. We have several other vendors that use our short-blocks exclusively because of our consistency & dependability.
Jason
Texas Speed & Performance
I use Ray-Mac Racing Engines for my Premium builds. Every build gets a build sheet, and DYNO TUNED before it ever leaves.
This was a shortblock so I never expected to get it broken in with dyno numbers.
Keep in mind, part of tuning a car is to do so with an understanding of the whole combination. That includes consideration of cleances, especially ring packages and how the owner intends to drive it.
Constantly people mention fuel/air ratios without talking about cylinder pressures/temperatures that will be generated under different circumstances. Example: Experience has shown me that a piston that radiates a ton of heat will require a wide ring gap if you want to really run the snot out of it. If a wide gap isn't used and the engine is run a little on the lean side, which in turn raises the heat put into the ring, it will expand, grab the cylinder and try to beat the ring land and the cylinder wall.
This is just one example and not intended to point the blame one way or another. Reading the plugs just gives you a better feel for things. Those little jewels can tell you if it's living a lean, rich or detonation enhanced life. They will tell you everything except a lie.
Also, it should be pretty simple to just look down in the bore with a light and see where the top ring gap is, as well as get a ballpark guess on the gap. That would have been the first thing I did.
just good to know that i'm not the only one with carcrafting issues that bust my ***.....and cost me money at the same time.
Hope everything works out for you.
Kurt
I have to go in the field again this weekend so I won't have a final word on what this will cost me until next week. TSP is having the machine shop tear into it and give me a price. I don't know how much "honing" is going to work cleaning up those jugs so I may just give up and start over.
Kurt
Kurt
