simple L92 question
1. how do you tell the front from the back of the block? (remember, this is a bare block at the moment)
2. there are tons of threaded holes.....which 4 do i use?
3. what size and length bolts should i use?
On the front of the block near the front main for the crank there is an indention area on both side. That is where the oil pump mounts to the block (under the timing cover).
Now as for bolt sizes and depth, no clue, as I've never put a bare LS block on an engine stand.... Hopefully someone else will pipe in with an answer for that.
Google Cache's is always fun though...
http://64.233.167.104/search?q=cache...lnk&cd=3&gl=us
The total length will vary depending on the stand you are using.
You can measure the thickness of the stand arms where the bolts run through,
then just add about 20mm to that for decent thread engagement.
Most stands will require the use of thick flat washers with a large O.D. to prevent the bolt heads from pulling through the stand arms.
