Our LSX is done
Old Jun 10, 2007 | 10:48 PM
Robin L's Avatar
LS1Tech Sponsor
Default Our LSX is done
Well we have had a lot of issues and setbacks but our LSX is done and should be running on the dyno shortly.
Doesn't look like many LS engines.
Here is a picture. The guy in the GMPP garb is the engine builder Jeff Stealy. Jeff has worked his butt of on our Nitrous 454 LSX engine. If it bolted to the engine it had to be modified in some way. Jeff has the ability to get things done.
If you guys want to purchase an LSX hat and/or GM Performance Parts T SHirts they are selling online over at gmperformanceparts.com.
Thanks
Robin
Old Jun 10, 2007 | 10:51 PM
sidewayz28's Avatar
HOLY.... that is amazing, and i want one.. great job guys
how much power you think ur guna make?
Old Jun 10, 2007 | 11:37 PM
Wnts2Go10O's Avatar
motor is beautiful.
his face says:"it sure is pretty, but god damnit...never again."...lol.
Old Jun 10, 2007 | 11:46 PM
Richard@WCCH's Avatar
Nice work Robin.
It's nice to see a few large displacement builds up and running. They're sure not an easy bolt together. Lots of detail and fitting to do.
Congrats on finishing this project.
Richard
Old Jun 11, 2007 | 12:52 AM
DONAIMIAN's Avatar
That looks nothing like an LS motor, lol.
Old Jun 11, 2007 | 01:33 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I know, I was thinking the same thing.
Old Jun 11, 2007 | 05:09 AM
OneQuickCoupe's Avatar
Super nice. Any word on the power output?
D.J.
Old Jun 11, 2007 | 05:24 AM
Adam_346's Avatar
that's really nice
Old Jun 11, 2007 | 07:44 AM
MeentSS02's Avatar
Kleeborp the Moderator™
That should put out a nice solid 300 HP...350 tops
Old Jun 11, 2007 | 08:01 AM
jamesSS's Avatar
Very nice. x3 on power out put.
Old Jun 11, 2007 | 08:18 AM
texinteg's Avatar
I am assuming thats a magneato setup that your running.
Old Jun 11, 2007 | 08:34 AM
Robin L's Avatar
LS1Tech Sponsor
No, that is a MSD Universal Belt Drive Distributor. It has a 1/4" belt that is driven off the front of the Jesel Belt Drive. The MSD Digital Programable is triggered by the Crank Trigger.
Looking for power on Motor in the 950+ range. Will spray an additional 4 to 5 on a NOS Pro Fogger single stage.
Richard, thanks, you understand how much it takes to get something like this done LOL.
Robin
Old Jun 11, 2007 | 08:55 AM
Jason99T/A's Avatar
I can shift faster than you.
Robin, what heads and bottom end components are in the motor? Compression ratio?
The motor looks very good!
Jason
Old Jun 11, 2007 | 08:59 AM
MSURacing's Avatar
So that must be a Pro-jection throttle body then. Funny, I can't see the fuel injectors. Must be a new proto-type from Holley!!!! LOL
Robin, why is the first GMPP's 454 not fuel injected? Seems to me this is a step in the wrong direction. I realize that sanctioning bodies mandate carbs and all, but you guys have pull there at the General and it is time to get EFI regulated in all racing classes. If you guys can't get the rules to change, none of us will be able to. Just a thought. Nice work though, that thing should put the old SBC's in the garbage.
Old Jun 11, 2007 | 09:03 AM
WickEdSix98's Avatar
Awesome build up, me and my dad have talked about doing the same type of build up for our Top Sportsman truck. It will be interesting to see how its going to run.
Old Jun 11, 2007 | 09:40 AM
Robin L's Avatar
LS1Tech Sponsor
Jason
Lunati Crankshaft
Diamond Pistons
GRP Aluminum Rods
GMPP C5R Heads Prepped by Don West
Compression ratio is 14.5 to 1
It took a ton of work by Jeff at Stealy to make this deal work.
Robin
Old Jun 11, 2007 | 10:34 AM
Bryan @ Speed Inc.'s Avatar
i think i need a new pair of shorts. that's gorgeous - i might buy a ring for it and propose...
Old Jun 11, 2007 | 10:46 AM
erikthegoalie's Avatar
Robin
Sounds $$$ lol
Old Jun 11, 2007 | 10:59 AM
texinteg's Avatar
Removed due to a half *** legal Issue.
Old Jun 11, 2007 | 11:10 AM
Noyzee's Avatar
8 second mod
Lunati Crankshaft
Diamond Pistons
GRP Aluminum Rods
Robin
i have the same pistions and rods, so i should be about 900 hp. lol jk.
looks great, man i was hoping you used a stock style oil pan. im tweeking over the grp rods hitting the oil pan, and i still dont have my parts back to test fit everything. doh.
when will it be in the car?
good luck for sure!!
off topic, tex, great looking set up
