manifold for ls3?
Old Jul 8, 2007 | 04:40 PM
Greg Fell's Avatar
Default manifold for ls3?
any different than l76 manifold? part number?
Old Jul 8, 2007 | 07:10 PM
See5's Avatar
The LS3 is insulated and looks different from the top. It is what that is inside that counts?????
http://forums.corvetteforum.com/show....php?t=1748056
Old Jul 8, 2007 | 09:51 PM
SilverBullet73's Avatar
I've heard it's the same as the L76. We'll know for sure in a few months.
Old Jul 9, 2007 | 07:11 PM
Greg Fell's Avatar
nobody? i thought a few vendors have dyno'ed them?
Old Jul 9, 2007 | 11:53 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm wondering also.
Old Jul 10, 2007 | 01:09 AM
SUTTERERMAN85's Avatar
Old Jul 10, 2007 | 01:21 AM
Jorday's Avatar
somebody has to know this....
Old Jul 11, 2007 | 09:50 AM
fastGBcamaro's Avatar
Default good
I dont know the answer to the question, but if it is the same as the L76 that would be great news, atleast for anyone running an L76 intake right now. This should help speed up the process of engineering a better flowing aftermarket intake that will support higher rpms, and wont break the bank like a sheet metal intake.
Old Jul 11, 2007 | 11:06 AM
White_Hawk's Avatar
Don't the vettes redline at 6600 now? The L76 would seem to be a little restrictive for that. Hoepfully, there is a new LS3 that flows better up top.
-Geoff
Old Jul 11, 2007 | 11:24 AM
See5's Avatar
What we are seeing from GM with the LS3/L76 is really state of the art as proven by FAST, Edlebrock, LPE and all the sheetmetal guys. A manifold that makes good HP AND torque while fitting under the hood of a C5/6 is a major challange.
Old Jul 11, 2007 | 04:45 PM
Haans249's Avatar
If you look closely at the front portions of the intake manifold, you can definitely see a big difference between the two manifolds. So, I'd say there is positively a new "LS3" intake manifold that is different from the L76.
Best Regards,
Adrian Mejia
Old Jul 11, 2007 | 06:18 PM
Cobraeater's Avatar
Arrow
Best Regards,
Adrian Mejia
Wrong, the LS3 has a accoustic shell that goes over the intake to reduce noise, so that is why the LS3 intake looks different than the L76 intake but it's actually not different underneath the shell.
Check this out.
https://ls1tech.com/forums/showpost....3&postcount=51
Old Jul 12, 2007 | 02:45 AM
Haans249's Avatar
Cool, thanks for sharing. Never saw that thread.
Old Jul 12, 2007 | 02:52 PM
Jorday's Avatar
According to info on corvette forum they are not the same. outer shell or not, they use different sensors and everything.
Old Jul 13, 2007 | 03:04 AM
ringram's Avatar
Check out the post from LG, all is revealed. Basically same as L76 with minor connector differences.
