RWHP guesstamate
Brand new GM LS7 7.0l block
Callies forged rods with ARP 2000 bolts
Mahle -4cc coated pistons with hellfire plasma moly rings
Eagle forged crank
Clevite H bearings
ARP main studs ARP head studs
GM MLS head gaskets
Isky cam mid 500 lift, 232 by 242 113 lobe sep camshaft
AFR 225 heads with 72cc chambers. Light cleanup porting new upgraded springs, titanium retainers, and 5 thousands off mating surface for cleanup.
Stock rockers, luntai push rods
LS6 intake 42 pound injectors stock TB
Kooks 1 7/8s headers Y pipe and corsa exhaust
What would be the cause of the low numbers?
Those heads a fast manifold and 90 mm throttle body
11 to 1 compression and you should be close to 500-500
I do not plan on staying with the intake and TB combo for long I have a harrop on order just have a while to wait till it gets here. Well that is if there was enough on my credit card, ill know tomarrow haha. If not I will install a ported fast 90/90.
I would have hoped a 427ci LS7, LS7 heads, nasty cam combo would be closer to 600rwhp than 500.
