What to keep if building an LSx
and what would you sell with the old LS block.
I know that the bolt on accesories stay. But from what I understand an LS1 PCM is not compatible with LS2 coil packs or vice versa. So what should you keep and what should you let go?
And what is the old LS1 worth (approx) without those items? (40K)
The first is the timing cover. The LSX needs an LS2 timing cover with the externally mounted cam sensor. The second is the lifter trays. The LSX has 6 head bolts per cylinder and the top headbolts get in the way of the lifter trays. GM sends out special lifter trays with the LSX block that are compatible. Hope that helps.
So if starting from a fresh build, you need to consider these thing when it come time to put it in the car and you find out something is not working. I want to feret out these things before I even start.
I'm using the top end minus cam from my 388 MID setup.
It's not theory. It's been done many times now. The link above has all you need to know for installing an LS2 block. I've done that and recently an LS7 crate engine.
