L92 and ls3 the same block?
Old Jul 29, 2007 | 05:09 PM
mpe331lx's Avatar
Default L92 and ls3 the same block?
I am wanting to build an lsx motor. I was planning to do forged ls2 with the l92/l76 combo with some spray.
Now I'm thinking about using the bigger bore block. I was looking at SDPC's site and found l92 blocks. Iam sure that the ls3 will be out soon. Does anyone know if there are any differences (or major differences) in the two blocks.
Old Jul 29, 2007 | 05:35 PM
drain89's Avatar
From my understanding they are the same block. I've read in a couple different press releases that 6.2 trucks and cars will share the same block. They were speaking of 08's. I haven't called my local gm parts guy and verified it yet. If they're any differences I'd say they were trivial. Sometimes parts have different part number but are identical.
Old Jul 30, 2007 | 12:27 AM
8ty8 LS1's Avatar
yes i believe that they're the same block.
Old Jul 31, 2007 | 03:59 PM
SSAUTOCHROME's Avatar
L92 is designation (coding) for Escalade & Trucks...LS3 is designation (coding) for performance cars...same **** different name as far as the block is concerned. The heads are different though...check out the sticky.
Old Jul 31, 2007 | 05:44 PM
blu00rdstr's Avatar
No difference in deck height? Truck blocks are usually taller...
Old Jul 31, 2007 | 05:50 PM
drain89's Avatar
no. same block.
Old Jul 31, 2007 | 07:19 PM
2000Firehawk's Avatar
http://www.motortrend.com/features/a...709_ls3_engine
LS3 block better in this article ?????
Old Aug 1, 2007 | 06:08 PM
drain89's Avatar
the l92 and ls3 motors share the same block.
it is "improved" over the previous 6.0 blocks.
