All Bore LS1/LS2
Old Jul 31, 2007 | 09:12 PM
Cobras_Rule's Avatar
Default All Bore LS1/LS2
The search is not working and im tired of searching... What good sites can I check out to get some pricing on an all bore shortblock. From what I see its around 387-388 ci... Is that sleeved or not? What is the max bore? 4.125?
Any help would be great! Thx!
Old Jul 31, 2007 | 10:39 PM
Beast96Z's Avatar
In order to go "all bore", you will need a sleeved block. The max bore depends on the type of sleeving process your choose,(wet or dry) and which block you get sleeved. (LS1,2,etc...) Max bore using the Darton LS7 dry sleeves in a LS2 block is around 4.185", and a Darton MID wet sleeve in a LS1 block can go out to 4.200". The only source for this large of a bore is R.E.D who is a sponsor. The 4.185" would equate to a 399 and the 4.200 would be a 402. Only other option is to buy the LSX iron block, which can also hit 4.200" safely.
Old Aug 1, 2007 | 06:54 PM
ok thx... ill look into it
Old Aug 5, 2007 | 09:53 PM
NemesisC5's Avatar
Are you building an "RPM" motor ?
Old Aug 6, 2007 | 11:29 AM
well currently im just looking into it
but yes i would like a high rpm motor
Old Aug 6, 2007 | 01:34 PM
NemesisC5's Avatar
Originally Posted by Cobras_Rule
......yes i would like a high rpm motor
Me too, not for just peak horsepower #'s, but for a combo that will have a wide powerband with the ability to scream when I want it to
Old Aug 6, 2007 | 01:38 PM
Stang's Bane's Avatar
Are you running in a class that limits displacement??
Old Aug 6, 2007 | 02:03 PM
no class... just would like a motor that really revs
Old Aug 6, 2007 | 02:08 PM
Short stroke does not necessarily determine a high revving engine. Valvetrain stability will determine the maximum rpms attainable from MOST LS type engines.
How many RPMS are you wanting to turn??
Old Aug 6, 2007 | 02:31 PM
MrDude_1's Avatar
no matter what number you say, you can spin a stroker to it too.
the limiting factor is the valvetrain, not the shortblock... all you're doing is giving up power.
Old Aug 6, 2007 | 02:33 PM
MrDude_1's Avatar
remember, the cam and such needed for actual power when you "scream" it at high RPMs will cost you power and efficentcy down low.
a cam set for a wider overall powerband can only rev out so far.... although increasing displacement (read: stroking it) further will allow you to widen that powerband more, without lowering the peak RPM the engine is capable of.
