need some advice on picking two 427 engines
Old Aug 27, 2007 | 04:19 PM
john_sblendorio's Avatar
Default need some advice on picking two 427 engines
I am looking at two different packages for a F1C ProCharger build and need help in picking the better package. I think the engines will flow about the same through the heads.
Option 1: $11700 + LS2 core
C5R block
Lunati LS1 4" Crank
Lunati Pro Billet Rods
Diamond or Weisco pistons
Stage III hand ported 243 heads
FAST intake
Jesel sportsman rockers
Option 2: $11000 - no core exchange
LS7 block
Eagle crank
Compstar rods
Stage III CNC ported L92 heads
L76 intake
L92 rockers
Old Aug 27, 2007 | 05:40 PM
WKMCD's Avatar
How about option 3. Selll your LS2 or trade it in and use the LS7 heads and intake. A FAST won't keep up like the LS7 intake will. The LS7 heads are killer.
My $.02
Old Aug 27, 2007 | 08:05 PM
I know the sky is the limit, but I was trying to stay on a budget and figured that I could upgrade to a FAST L92 should it hit the marktet later on or sell the L92's and upgrade to a LS7 top end should the fund become available. Option #2, seems like the least expensive way to build a reliable motor capable of handling 800hp.
I guess the real question is - is the C5R/Lunati/Lunati kit worth the extra dollars over a LS7/Eagle/Compstar? I would expect the two listed top ends to flow about the same.
Old Aug 27, 2007 | 11:01 PM
Chicago Crew UnderBoss's Avatar
My $.02
I say option 1 as you can't beat the C5R block and if the extra $ is affordable I would go that route and keep in mind that when it comes to f/i via cent. supercharging the heads are not nearly as important in making huge power vs N/A applications and N20.
Old Aug 27, 2007 | 11:19 PM
LSmonster's Avatar
Option 3: ERL Super Deck block. Tested at OVER 1600 HP!... I've used 8 of their blocks with no issues... Give them a call.
Old Aug 27, 2007 | 11:39 PM
Jantzer98SS's Avatar
Option 4:
SDPC Big Bull L92 427 around $8k longblock
Old Aug 28, 2007 | 12:49 AM
Tom@SpeedInc's Avatar
C5R blocks are great if your running LS1 style computer.
IMO, i'd go with a set of aftermarket heads though, thicker deck for forced induction.
Old Aug 28, 2007 | 01:16 AM
Ferocity02's Avatar
Option 1 seems to be a better platform of those two. What are your goals though? IMO you can build a stouter engine than either of those for less cost. Start with an LSx block, which is already a third of the price of the C5R block, and use roughly the same components.
Old Aug 28, 2007 | 04:46 AM
98transguy's Avatar
i would go with an lsx block personally but out of the 2 the first option has better parts in it,except for the heads where i would go after market with those
