Howard Sharp AL Roller Rockers.
Old Oct 3, 2007 | 07:46 PM
blackangel327's Avatar
Default Howard Sharp AL Roller Rockers.
has anyone used the Howard Sharp Aluminum Roller Rockers before??? there 396.99 for the 1.7 and 409.99 for the 1.8 from Scoggin Dickey's and like 409 for both from jegs.
http://www.jegs.com/webapp/wcs/store...49542_-1_10231
Old Oct 4, 2007 | 07:39 PM
HEMIETR's Avatar
Howards suck. I would go with some yellow termites.
Old Oct 4, 2007 | 10:39 PM
adams2003's Avatar
Its harland not howard.....harland sharp is a very reputable company that I am running with good results
Old Oct 4, 2007 | 10:49 PM
blu00rdstr's Avatar
I hear nothing but good things about Harlan Sharp. They do rebuild stock arms with captive bearings, about $250. Never heard of them break.
Old Oct 5, 2007 | 06:10 AM
WKMCD's Avatar
Old Oct 5, 2007 | 07:14 AM
ramairws6's Avatar
He!He!He!
Old Oct 5, 2007 | 07:59 AM
nesikachad's Avatar
JESEL
Did I say JESEL? I did say JESEL right?
JESEL!!
Old Oct 5, 2007 | 11:20 AM
Richard@WCCH's Avatar
Hmmmmm..........wooden rockers?
Richard
Old Oct 5, 2007 | 11:53 AM
trik396's Avatar
Harland was the first to manufacture roller rockers probably 40 years ago. Well respected everywhere. I find it interesting that someone would knock them when they don't even call them by their correct name. Seems this site has alot of knowledgable people, but some who couldn't find the water if they were standing in a boat.
Have run Harlands stuff in big and small chevys for decades with never a problem.
Old Oct 5, 2007 | 12:04 PM
WKMCD's Avatar
WTF - No one diss'd HARLAND Sharp here. Better read the thread again before you spout.
Old Oct 5, 2007 | 12:12 PM
trik396's Avatar
Don't feel like reading it again.
Old Oct 5, 2007 | 12:27 PM
Old SStroker's Avatar
Richard
Ash is nice and springy. You can really get some nice loft! It also takes stain quite well, but it needs a fairly flexible urethane to protect it from the oil. Somewhere I have pics.
There are some good things about the OEM LS rockers, with the exception of the fairly cheesy fulcrums. Harland Sharp offers replacement needle bearings and fulcrums.
There are other methods of improving the basic OEM arm which is a nicely designed piece with very good stiffness and rotating moment of inertia. A non-roller tipped arm is inherently stiffer than a roller-tipped arm. If the replacement fulcrum is also stiffer than stock, you may end up with a modified stocker that is stiffer than any roller aftermarket arm. This is a very good thing with aggressive valve action.
Old Oct 5, 2007 | 02:22 PM
I'm right with you on beefing up the oem rockers with Harland Sharp's replacement trunion bearings. They work extremely well for most street applications. The roller rocker systems have a place in the aftermarket, but they're not an absolute necessity as they were with the older Gen Chevys.
Ash is definitley nice, but cedar might freshen up the the under valve cover odor...........
Richard
Old Oct 5, 2007 | 04:53 PM
OneQuickCoupe's Avatar
I have never had any problem using polyurethane on any none oily material in fact it is quite flexible. Jesel does make a fine product.
D.J.
Old Oct 5, 2007 | 05:03 PM
eallanboggs's Avatar
Do forget to consider the new Scorpions. The quality is as good as all the well know aftermarket brands. They have a large trunion bearing. $379 @ SDPC in either 1.7 or 1.8.
Old Oct 5, 2007 | 06:58 PM
well its going on an LS motor, not an older chevy motor
Old Oct 7, 2007 | 11:54 PM
Mike94ZLT1's Avatar
Originally Posted by nesikachad
JESEL
JESEL!!
They're JESEBEL's dummy
Old Oct 8, 2007 | 12:17 AM
Black FormulaLs1's Avatar
maby this should go to a poll?
i have heard decent things about the scoprions and have thought about purchasing some myself..but dont know about any warranty, or anybody else really putting them to 7K rpms..anybody here running them? if so, have you noticed any difference? pros-cons? thanks! also would be going into an LS engine
Old Oct 8, 2007 | 02:48 PM
Nasty N8's Avatar
I can set you up with Harland Sharps cheaper than the other guys give me a call.
Nate
