Oil priming
Old Nov 4, 2007 | 05:34 PM
bluethunder364's Avatar
Default Oil priming
When the time comes what is the proper way to prime my oil system in my 6.0 LS2 block?? The drill through the dist. hole no longer applies here. Thanks
Old Nov 4, 2007 | 07:24 PM
koolrayz's Avatar
I just rolled the car over with the plugs out for about 30 seconds after it had good pressure. then finished putting the engine together and fire it up.
Old Nov 4, 2007 | 08:01 PM
Default Oil Pressure
I guess that is the only way, Thanks again
Old Nov 4, 2007 | 08:55 PM
NemeSS's Avatar
bumo over the motor with out the plugs,
has worked fine me as well before
Old Nov 10, 2007 | 07:20 PM
barnat's Avatar
Default use a distributor LS drive cover
Iam ready to pick up my forged364 lq9 from my local mach shop and am thinking of buying a ls dist front cover to prim my engine,i think ther pretty cheap from what a buddie has said,Butif its like 50 to 60 bucks Hell im gonna pick one up to to satisfie myself LOL!!its part #88958679 in **** ,ill sell it on here for half price after useing it once, to just prime my moter LOL !! just a thought
Old Nov 11, 2007 | 07:47 PM
itslow's Avatar
The front cover with the distributor drive won't do you any good, as the oil pump is driven directly off the crank, not the distributor shaft as in the SBC/BBC engines. The crank needs to turn in order to cause the oil pump to pump oil.
Old Nov 11, 2007 | 07:52 PM
cherryelky305's Avatar
There is a plug on the drivers side of the block, behind where an F-body alternator sits. That plug leads to an oil "tube"(for lack of a better word), anyway you just take the plug out and then pump oil into the motor until you see oil in the valve train. Thats the only way to really "Prime" the oil system. Most people just crank it some until it builds pressure.
Here is a pic.
Oil at the lifters.
Old Nov 13, 2007 | 07:46 PM
barnat's Avatar
Default thats the ****
I never knew that ! Thanks Your my Hero for the day LOL!! thanks man REALLY!!
Old Nov 13, 2007 | 07:50 PM
3.4camaro's Avatar
pull the ignition relay and fuel pump fuse and crank until it builds.
Old Nov 14, 2007 | 10:32 PM
bigdsz's Avatar
GM actually has a primer kit that can be bought. I used one from a local Chevy dealership. There was minimal lag before we got oil pressure.
Old Nov 15, 2007 | 11:33 AM
Dale C's Avatar
I have a primer I bought from an aircrft engine company. It is a pressure pot design, you put the amount of oil you want in it and put 50 psi of air pressure in the top hook it in any oil galley and open the valve. It is a pretty trick little deal, it has a ph1 filter on the side and a pressure regulator.
Sorry I cant remember the company I bought it from but you may want to do a search for aircraft engine tools. I think it was about $300 I use it on everything now, even non LSX engines it is easier than pulling the distributor and you can start the engine right away before the oil has a chance to drain all the way back.
Old Nov 15, 2007 | 06:49 PM
gen3performance's Avatar
I built my own oil accumulator out of a propane tank. You essentially weld a pipe and cap on top to fill it, have a tube that goes from the bottom of the tank to that plug in the above picture, and finally have an air line hook up at the top of the tank. Fill the tank with oil, hook your line to the engine, and the air pressure will force the oil through every spot in the engine.
Many machine shops around here have them for diagnostic purposes. You are able to find internal engine leaks with the pan off and and engine off.
Just dont use more than like 60psi incase of some sort of rubber seals in certain engines.
Old Feb 14, 2008 | 12:03 AM
SMAX's Avatar
Here is a pic.
Oil at the lifters.
do you by any chance have a better of where that plug is? and is it threaded or how do you remove it?
