Convince me to build LS instead of BBC!!!
I'm 100% in agreement with you on one thing for sure - for a '70 Chevelle, it's a no-brainer. Big block all the way, baby!
I figured you were gonna go with the big block anyways. Which is a great choice. The 71 chevelle I was talking about has a turbo big block going into it now. But I really can't go into that. But it should make some good power. You'll be happy with it. As far as cost I don't know if it will be any cheaper. I sure hope you are going with EFI and not a carburetor. Cheers.
turbos where always in the back of my mind but the added fab work always scared me. if the common opinion that turbos would be that much easier without much of a price difference then turbos it is. EFI was a no brainer a while back ha. I kno the majority of you are camaro firebird, gto experts but if turbos are the answer can we slowly change the topic to fitting a twin turbo kit that would fit into a chevelle (a-body).. any good sites that offer cost effective parts or a point in the right direction.
4 years ago, a 540 on the street was considered way over the top. Now there's plenty of 632's running around in street trim.
Anybody that thought the days of muscle engines has passed has apparently not checked out what's happening these days. 10 years ago, technology to build the engines we're talking about didn't exist, particularly among the sportsman crowd. Now we can compare STREETABLE 700hp aluminum LS blocks and 1000+ hp big blocks in street cars. I bet the Ford guys ain't having this much fun!
http://www.shafiroff.com/sportsman/555_900.asp
Their pump gas 565 is a couple grand more, but I can guarantee the quality of parts and workmanship at Sunset Racecraft (www.sunsetracecraft.com). The pump gas 565 is the baby of the bunch, drool away at their 738 Iceman engine. Even with full exhaust out the dyno room, that SOB is LOUD and puts a real strain on the dyno! These guys got the first 6 of Brodix's new aluminum big blocks when they first came out for R&D and helped 'em work out the bugs and have had a hand in a good bit of Brodix's cylinder head development and testing. They're very highly regarded nationwide thanks to their attention to detail and workmanship. They do all my machine work and will as long as possible.
They have their ULTRA STREET "582ci SS", 582ci/825 hp, with all the upgrades like Callies internals, coatings, etc.... A 250 shot fogger system installed, all electronics (MSD) and extras to receive it and install it in the car and start it up. $18,100 dyno tuned ready to install. Plus I would have to have custom exhaust, which costs $1,500 from a BADASS shop here in Lauderdale.
Its a low deck and they said it will fit into the WS6 with out any fabbing. That seems a little strange though that it'll fit right in. It has the same exterior dimensions as a 396ci engine, so maybe it will.
The warranty covers ALL parts that might fail in the 2 year period, but if a part takes the block out the block is not covered.
That would be pretty cool to have in a WS6 street car. They said it's just fine for daily street driving.
Just reporting what they said.
you'll never be able to touch that performance per dollar with a LSx, no where close.
That kind of performance and price point is the very definition of a pipe dream to the small block world.
For a stout 402 build, badass hand ported Trickflows, solid roller, solid roller, knifed crank, rods, pistons, all premium stuff, including labor... I had a quote for $28K with a few thousand for slush fund... and that's including all the other stuff needed, like serious upgrades to the fuel system and a nice dry sump setup. What was the power? going for minimum of 550 on a 'stang dyno. Could run to 7500, but for my roadracing I don't want to stress it. Point of the story? You could try the LSX iron block and go nutso on it, but it'll cost way more than a BBC.
It sure wouldn't be as fun as a BBC at the end of the day.
1) Lazy engines are happy engines. The 427 fords back in the day proved this at 24hr LeMans.
2) Your not stressing a BBC remotely near as much as a LSx when you start going over the 600hp mark.
3) What other engine could sit there and induce brown notes to unsuspecting people?
damn, your making sad that I went with a road track car instead of a haul *** car.
Its very hard to take the LS side of things if you just look at head flow, size of parts and amount of reasonable priced (compared to LS engines anyhow) aftermarket parts. I have a feeling when the bigger inch tall deck LSX stuff comes around then you may start seeing some more bottom end failures, BBC stuff is stout down there but OTOH a cross bolted deep skirt block is no slouch either.
But there is more then just HP output IMO when doing a build. To me the nice thing about the LS engines is they are still something different, extremely easy to work on, never leak, are lightweight and they arent very common still so they attract a little more attention. My car with a 632 and nitrous would be much faster no doubt but people 'expect' a big inch BBC to be fast. I can honestly say that I have never had a leak free, never having to scrape gaskets, lightweight and reliable 9.0x fully streetable 3400lb car as this one with a BBC. But most of that I attribute to the wonderful combination of forced induction and EFI, plus commonly available widebands I didnt have 20 years ago
But in the end ts just hard to beat those giant canted valve heads and big ports plus 40 years of evolution. In answer to the original poster if I had a 70 bu it would just have to have a BBC, SBC and LS engines look lost under the hood of those things
Either one will provide the power you want reliably so for me it would boil down to aesthetics, ET/weight goals and dollars and sense more than anything else. All standard deck big blocks are dimensionally the same. Doesn't mean it's not work to shoehorn one in. Look at how tight an ls1 fits under our cowl. A big block is gonna be some work.
You could order the long block and EFI stuff for the BBC and be done. Spend the extra money on suspension, brakes etc to make the car drive better instead of just having a car with the wow factor engine.
My current car (import I am asshamed of) turned me off of being one of the first guys to do this or that with no real support for tuning or parts. That is why I am coming to the LS side. I want what everyone else has tried and tested before I lay down the cash. I am starting this time with a plan before I even buy the car.
Put a BBC in that thing like everyone else does and forget about it. EFI on that monster will be enough to get plenty of attention at the car shows. There is a reason they run BBC in power boats. They are strong!
thats another reason i chose the BBC.. every possible build up has been done before and i guess for a lack of a better word, a BBC build is more established.
EFI is for sure... as of now im about 70% twin turbo and 30% procharger.. im gonna have the car for a while and i love the adjustability of turbos.. the packaging the plumbing is the only part that turns me off...
The king of STREETABLE 7 second cars...TT BBC or TT SBC and now even the TT LSX iron 454ci:
Is www.nelsonracingengines.com
http://store.summitracing.com/egnsea...5&autoview=sku
