Convince me to build LS instead of BBC!!!
http://www.ultrastreet.net/598_classic.asp
WOW!!!
I spoke to Gayle Banks awhile ago, he's one of the top turbo engine builders on the planet. He has TT engines that make 1,600 hp, built for street use, that can be turned up and down while you're rolling to make 500 hp up to 1,600 hp. It simply operates the waste gates via pocket computer.
The blower will than block the air for your street tune and it would run horrible. I don't think is done.
Twin turbo or big single turbo will do it. You don't ever touch the belts, you just pick up your hand held computer and push a couple buttons.
Look at this: 522 BBC Twin Turbo. 2,000 hp with boost controller turned up....1,000 hp with it turned down. You can do the same thing with a 1,000 hp TT BBC, turn it down to 700-800 whenever you want. This guy is the king of TT engines.
http://www.youtube.com/watch?v=zUOOK06UrZs
in reference to the procharger build and my street tune... why cant I just take off the piping from blower to throttle body and slap a cleaner on the TB. this way it wont block airflow....
yet another idea for the procharged street tune... cant i put the biggest pully on the blower and adjust the bypass valve to bleed off the majority of the boost.. this way id only be getting say 2lbs of boost?
any comments on this?
im just trying to figure out this procharger vs TT deal..
It can give you exactly what you want....650 RWHP during street driving and then turn it up to 1,000 RWHP for the races.
And anywhere inbetween.
I guess what im trying to figure out is if pulling the belt, removing the piping or adjusting bypass valve is doable on a procharger for a street tune...
i kno turbos are the epitomy of this but i guess im playing devils advocate to see if prochargers are capable of this..
I'm no 1/4 mile drag expert but I think thats exactly how it works. Other guys can chime in with the specific ET's and whats needed as you run faster and faster.
If I had to guess, running in the 10's....you need a suit, helmet, full roll cage. There's definitely a few more things but I'm not sure what they are, like a certain type of flywheel is even required.
For running 10's though, its not really alot of things needed.
http://nhra.com/tech_specs/ETQuickRef.html
Put yourself in their shoes - how would you handle it if you let an otherwise solid 10.5 second or faster car run without a rollbar and it got squirrely at speed and killed or seriously injured the driver? A driver signed release of liability isn't worth the match it takes to burn it, it'll still be his *** if something goes wrong.
Why would you want to run faster than 10 seconds without a full cage anyway? Many cars actually run faster with a roll bar/cage due to increased chassis stiffness. That's hauling the mail and bad **** happens incredibly fast at that speed - way faster than you can react to it. If you're asking these questions, I take it you've not done a lot of racing at the track? Trying to handle a sub-10 second car without a good bit of racing experience isn't something very many guys can do, they can get away from you in the blink of an eye and the consequences aren't good. Big horsepower is damned dangerous.
Shoot me a message anytime if you have any questions....
i kno the turbos are the epitomy of different tunes but its alot of fab and money i dont kno if i want all that under my hood... i kno dont shoot me down twin turbos are nice but a clean engine bay is a fetish of mine..
nitrous is the cheapest initially but with a big shot i need to deal with race gas and 8 more injectors..
procharger would be great.. however i mentioned b4 that my street tune would be to either pull the belt and piping or somehow put on a big pulley and bleed alot of boost off from the bypass...
comments please!!!
